Home › Forums › Manufacturer/WP/Insurer Specific Forums › ISE Trade Support Forum › 1606 bearing changes
- This topic has 20 replies, 5 voices, and was last updated 13 years, 11 months ago by
eastlmark.
March 24, 2014 at 1:42 pm #373779
ModeratorRe: 1606 bearing changes
squeak is hopefully just a riding up belt on the pulley as above. I have never known any washing machine drum look central if you ( or more likely the user) watch it long and hard enough. Front plate should fit right on centrally- never had an issue.
March 24, 2014 at 9:58 pm #373780trotter
ParticipantRe: 1606 bearing changes
eastlmark wrote:squeak is hopefully just a riding up belt on the pulley as above. I have never known any washing machine drum look central if you ( or more likely the user) watch it long and hard enough. Front plate should fit right on centrally- never had an issue.
Well thanks for the useful reply Eastlemark fingers crossed!! I should be going back on Thursday 🙂
March 25, 2014 at 10:30 am #373781Allsorts
trotter wrote:Customer describes loud squeaking noise on drum rotation and really loud on the fast spin
If the squeeking is not the belt, it may well be the seal if it is either dilapidated or dry; take some silicone with you. The seal is usually easy to push into place with a flat object and the stale of a hammer.
trotter wrote:also the drum is not exactly central! How the hell do you get that front plate in the exact right position without the 3 legged tool as in the dvd? I spent ages trying to get it exactly right……seems I failed :-{
As for the front plate; you could remove the cast weights and tilt the machine backwards. The plate aligns without any problems this way.
March 28, 2014 at 11:15 am #373782trotter
Having visited yesterday I found that the squeak was probably the wrong description……although the belt was a LITTLE noisy. everything is fine until the machine gets up to a fast spin at around 9 of the 15 minute spin cycle completed, then it just gets really noisy – it sounds like a dry bearing and there is the slightest bit of “play” in the drum. I will chase up the parts that I ordered last week (Bearings & seals) and report back in a couple of weeks when completed!
Thanks for taking the time to comment.
March 28, 2014 at 3:08 pm #373783Allsorts
Are we still talking about the bearing change that you did in early February? If so, and you’ve used the correct bearing, I would say that it is near-on impossible to have a bearing become noisy that quick; unless of course you have nicked/damaged it during fitting.
April 7, 2014 at 10:50 am #373784trotter
Same bearing change!! been on holiday and am planning to fit new bearings this week 🙁
Never had bearings this noisy after such a short time before, but this is the first 1607 bearing change for me. I have to say a puller would make it loads easier and the fact that both bearings are the same size doesn’t help when getting the drum back in. -
