Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › AEG 86070VI i30 Leak Prevention but there is no leak
- This topic has 15 replies, 2 voices, and was last updated 7 years, 8 months ago by
george10.
August 10, 2018 at 8:35 am #94401
george10
ParticipantMy AEG Favorit 86070 is beeping 3 times and displaying i30.
I understand this is the leak prevention system and have read loads of stuff online about water in the bottom tray and the polystyrene float that then activates a microswitch.
The problem is, I have taken the back off and looked and there is no water in the tray at all. The polystyrene float is down and the microswitch is not activated.
But still it constantly goes into i30 and the drain pump runs (and from what I can tell it is actually draining out).
Is there anything else that could cause this fault?
Thanks.
August 10, 2018 at 12:07 pm #457222electrofix
ModeratorRe: AEG 86070VI i30 Leak Prevention but there is no leak
there is a service bulletin on this machine that shows the pressure chamber that is a rubber pipe at the front of the machine can sag and give this error
August 10, 2018 at 1:11 pm #457223george10
ParticipantRe: AEG 86070VI i30 Leak Prevention but there is no leak
Dave,
Thanks for that – I’ll take a look later – is it basically a case of using a cable tie to lift the black hose up?
Does it give any info about how it detects that scenario – is there a sensor somewhere?
August 10, 2018 at 1:49 pm #457224electrofix
the hose leads to a pressure sensor that detects water height
August 10, 2018 at 7:28 pm #457225george10
I’ve looked and the hose doesn’t appear to be sagging 🙁
Wondering what else it could be.
Saw this thread
favorit-88070-error-code-water-inlet-solenoid-fault-t78636.html
which I think you posted in.Could it be the solenoid in the hose? Where can I put a multimeter on it to check resistance? Can I do it without removing it from the machine?
2.7m hose on AEG site is £76!!
August 10, 2018 at 8:36 pm #457226electrofix
i30 fault from manual
August 10, 2018 at 9:04 pm #457227george10
Does base trough refer to the “tray” underneath where the float polystyrene bit is?
Because if so that bit is dry, so the only thing it’s suggesting is inlet valve. Is that the solenoid in the hose as mentioned earlier?
August 10, 2018 at 9:21 pm #457228electrofix
yes
to test it you would need to get at the connection to the valve, disconnect them and measure the coil resistance
DaveAugust 10, 2018 at 9:48 pm #457229george10
I’ve just lifted the inlet hose out.
Now if I get my multimeter, set it to resistance and put the probes on the small metal clips on the end of the blue and brown wires…..it doesn’t register anything. Does that mean the solenoid is faulty? The other thread implied there should be 3.7k resistance? Assuming I’m measuring right?August 10, 2018 at 11:02 pm #457230electrofix
anywhere from 3000 to 5000 ohms is ok
check your meter is on correct scale
August 11, 2018 at 8:49 am #457231george10
If I up my meter to 20MegOhm I sometimes get something but to me that seems far too high.
August 11, 2018 at 9:19 pm #457232electrofix
without a doubt seems to be faulty
August 12, 2018 at 9:42 am #457233george10
Would this be the right replacement part?
https://shop.ukwhitegoods.co.uk/d449001 … hose-valveSomewhat cheaper than the genuine AEG one.
Should it be easy to fit (the end that connects into the dishwasher, looks like there is a metal clip that goes over where the inner hose attaches on, from what I can see)?
(don’t want to inadvertently introduce a leak!!)
August 12, 2018 at 4:28 pm #457234electrofix
i cannot be 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} certain as there are 9 machines with the same model. i would need your complete pnc number to check
the one i looked up is
FAV86070VI PNC 911235143 00from the manuals there are 3 hoses
111 57 65-00 / 8 1.8M111 57 65-10 / 7 2.7M
111 57 65-20 / 6 4.0M
the hose you have linked to is a match for the 1.8M one
August 12, 2018 at 6:18 pm #457235george10
Thank you Dave.
Mine is PNC 911 235 210 01
Is that the same hose?
