AEG F99705CI1P Dishwasher leaking from front.
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries AEG F99705CI1P Dishwasher leaking from front.
Viewing 4 posts - 16 through 19 (of 19 total)
  • #468863
    thats a point are they using rinse aid and 3 in one tabs ?
    meaning double dose rinse aid
    kaibart
    I would agree with dave they are probably over dosing, also there maybe a dry function on the dishwasher so have the side panels off and check the filter in the air chamber
    #468865
    Twoten
    I think I’ve found the problem.
    I returned to have another look at this. As I couldn’t see a split in the spray arm I thought I would test it just in case.
    I took it into the garden and connected a garden hose to the inlet and held it at arm’s length. With water flowing through the spray arm I noticed a spray coming out the end where the secondary spray arm nut attaches.
    Removing the secondary spray arm revealed this.
    I was looking for a split along the arm as I’ve found with other makes, I’ve never come across this.
    New spray arm on order to be fitted next week. I’m pretty sure this is the problem but will post an update to close this thread off.
    #468866
    Twoten
    Just to update this thread.
    Machine run through several washes without any leaks.
    Thanks, everyone for the advice.
