AEG L16810 Not drying
Viewing 4 posts - 16 through 19 (of 19 total)
  • #135391
    Re: AEG L16810 Not drying
    Ah well I am an electronics engineer by profession so it’s kinda like a 6th sense.
    Hold a requisite number of buttons down and switch on!
    Now all I need to find out now is what all the test settings are!
    Neil
    #135392
    litlor
    hope this is what you need
    [DELETED]
    Good Luck
    John
    #135393
    Hi Guys, sorry but you can’t post the full fault code list in a public forum because…
    The person attempting the repair might fry themselves by mistake and try to sue us. 😕
    The manufacturer could attempt to sue us for breach of copyright if the material is protected under copyright, which is a huge grey area I don’t wanna get into.
    Sorry guys but we have to stay on the right side of the law whether we agree with it or not.
    lcsneil
    Just to say thanks to the folks on here I now have a fully functional machine again.
    Just to let you know that the Error code E72 help. “NTC sensor on drying condenser faulty.”
    Well this was the only one I hadn’t tested and was thrown slightly as one of the previous posts had said that if it didn’t work on manual dry then it was unlikely to be a sensor fault.
    Anyway went to check it and one of the wires came off in my hand.
    One cut connector and two spade terminals later I am back in business.
    Reason it went in the first place I reckon was the wiring harness was tight (the connector had been fed around the wrong way) and so the machine vibration had caused a lot of strain on the wire, hence the original intermittency of the problem.
    Thanks again guys ‘n’ gals
    Neil
