Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › AEG Microwave/Oven Error code meaning
- This topic has 15 replies, 3 voices, and was last updated 5 years, 1 month ago by
sirocco.
February 16, 2021 at 1:32 pm #99150
sirocco
ParticipantI have an AEG Microwave/Oven model no KR8403101M displaying error code F134 , anyone know what this means?
It occurs about 20secs into the microwave heating cycle and shuts down machine, often machine restarts a few minutes later.February 16, 2021 at 7:40 pm #475183electrofix
Moderatorthis is not going to help you a lot as they dont explain it properly
February 17, 2021 at 8:46 am #475184sirocco
ParticipantThanks Dave,
Looks like poor translation.
There doesn’t seem to be any Analogue to digital converter but I guess they mean the oven voltage filter which looks like it smooths and rectifies the power board supply voltage.
AC to DC ?
I have changed the power board already so the problem is of board and most likely in the power supplied to the board from the filter.
Ill give it a go and see what happens.
Thanks again
GrahamFebruary 18, 2021 at 5:12 pm #475185sirocco
ParticipantHi Dave,
Have changed the filter, same error message.
Do you have any information as to where the Analogue to digital converter is located?
GrahamFebruary 18, 2021 at 8:35 pm #475186electrofix
Moderatori assume its part of the power board but there is no more info on it
February 19, 2021 at 9:06 am #475187sirocco
ParticipantIm now getting an F131 error code ! is that pointing towards the same area of problem?
GrahamFebruary 19, 2021 at 9:50 am #475188electrofix
ModeratorFebruary 19, 2021 at 3:57 pm #475189sirocco
Not bad considering there’s no steam in this unit.!
Whats needed is an AEG/Electrolux circuit diagram for this unit/model range but I guess they’re unavailable?
GrahamFebruary 19, 2021 at 4:01 pm #475190electrofix
Moderatorall the diagram will show you it a big oblong to represent the power board etc and lots of connectors coming off it going to various components
never found them much help to be honest as it does not show connections that go through the board
February 28, 2021 at 2:33 pm #475191sirocco
ParticipantSorry to be a pain Dave, I’m getting F130 error now do you know what this indicates please.
GrahamFebruary 28, 2021 at 2:36 pm #475192electrofix
Moderatoryou sure getting a mix of errors
February 22, 2022 at 1:52 pm #475193Mak85
ParticipantHi there. I am having a very similar problem with my aeg kmk721000m microwave grill too. I get the f134 error and the microwave sometimes clicks on and off and on and off again. I have changed the transformer, hv capacitor, hv diode and the magnetron but still get this problem of random shut down. Did you ever rectify the problem yourself?
I’d really appreciate your help on this if you do have a solution.
Regards
February 22, 2022 at 1:53 pm #475194Mak85
ParticipantIn addition to the last I have also replaced the PCB but still to no avail. I can’t think of many other parts actually left to replace other than the door switches or the hv filter? Any suggestions?
February 22, 2022 at 2:21 pm #475195electrofix
Moderatorthey are not too helpful about this code
knew it had nothing to do with mag etc and looks like a board failure but you say you changed itaccording to the tech the only analogue input is the oven probe. long shot check food probe socket for contamination
other poss analogue inputs are any other temp probes. i would check for earth leakage on them as something is upsetting the boardDave
February 22, 2022 at 4:22 pm #475196Mak85
ParticipantHi again Dave. Thanks for the reply. Do you suspect that it won’t be the voltage filter like the OP?
Where would the food probe socket be exactly?
