Any washing machines that work with low water pressure?
Home Forums General Trade Forum Any washing machines that work with low water pressure?
Viewing 16 post (of 16 total)
  • #182483
    bassman
    Re: Any washing machines that work with low water pressure?
    There are two solutions to this problem you can buy a low pressure solenoid valve or you can get a booster pump these are used on commercial machines to boost hot water pressure to to the same pressure as mains water not cheap but would solve the problem you wire the pump to the water solenoid via a relay if the booster pump doesn’t have one when the solenoid switches on the pump comes on and raises the pressure of the water.
