Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Ariston ADL120FR Washing mach bearing kit-determining model?
- This topic has 19 replies, 5 voices, and was last updated 20 years ago by
admin.
March 26, 2006 at 6:22 pm #170363
ModeratorRe: Ariston ADL120FR Washing mach bearing kit-determining mo
Please don’t tell me you have a Scandinavian relation.
http://www.ukwhitegoods.co.uk/modules.p … t=yurtesenMarch 26, 2006 at 6:59 pm #170364admin
KeymasterRe: Ariston ADL120FR Washing mach bearing kit-determining mo
What a coincidence that my cousin Evren had almost the same problem with his machine! 😉 Just kidding!
We’re not related exept in that we like taking pictures of washing machine innards. I think I know when to throw in the towel where as he never ever gave up. Makes Winston Churchill look soft! Certainly an amusing read though 🙂
In the case of my machine, it the seal that failed and rusted the inner bearing which then damaged the drumshaft and that a new drum would be in order?
I’ll be glad to just scrap the damned thing and get a new machine.
Cheers,
Phil
March 26, 2006 at 8:00 pm #170365Penguin45
ParticipantRe: Ariston ADL120FR Washing mach bearing kit-determining mo
Your third picture shows the worst – the shaft is stepped in and is now undersized where the bearing will sit. It will therefore be loose inside the new bearing, so the seal won’t work.
Unlucky…….
Penguin45.March 26, 2006 at 9:08 pm #170366admin
So I should forget about this machine then?
I imagine the amount of money, time, and effort it would require to replace the drum just isn’t worth it. Looks like we’ll be buying a new machine.
And I thought Ariston go on, and on, and on. Aparently not 😕
Thanks again for all your help.
PhilMarch 26, 2006 at 9:38 pm #170367iadom
The advertisers forgot to add the last line,……….on and on, the tip. 😥
Cut and run, if you fit bearings to this they will fail very quickly. I doubt that Martin will make such a generous offer this time around, 😉
The old adage, “you get what you pay for” is as true today as it ever was, particularly in regard to domestic appliances.
