Ariston AWD12 not emptying or spinning
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Ariston AWD12 not emptying or spinning
Viewing 7 posts - 16 through 22 (of 22 total)
  • #189636
    Re: Ariston AWD12 not emptying or spinning
    Since when have Ariston carried a 5 year parts guarantee? 😕
    #189637
    Can I order it and fit it myself? I have taken the old one out already.
    #189638
    Martin wrote:Since when have Ariston carried a 5 year parts guarantee? 😕
    The ones based on the Hotpoint WMA do, not sure about the Indesit clones but I think they do as well.
    scs102 wrote:Can I order it and fit it myself? I have taken the old one out already.
    Don’t be silly. 😉 They will not supply you with free parts, unfortunately you are not qualified to diagnose the fault in their eyes and you have already compromised your five year parts warranty by removing the parts.
    Best advice is to put it back very carefully, phone them, say nothing and pay the labour charge. Much cheaper than making a wrong diagnosis.
    HankMcSpank
    I know this is an old thread, but I found it via Google.
    I have the same washing machine (AWD 12 UK) & following the advice on this thread, it looks like, the 10 flashes & constant dial turning is likely to be the PCB. Here’s a photo of the general PCB …
    & the specific area of burning…
    What are my options here?
    I see earlier in this thread that there was talk of a 5 year warranty on parts. The label on the back that implies this washing machine was manafactured in 2003.
    There a barcode with the following numbers on it, not sure which is the serial number…
    080260960030
    31 765 310013588
    Is anyone on here able to confirm that one of the above is a serial number (or tell me where it will be?!) & also which month it was manafactured?
    if it is in the 5 year warranty period, can you please outline who I should call & what info they’d require?
    Many thanks,
    Rob
    PS if it’s out of the warranty, I’m guessing I just can’t buy the part?
    There doesn’t appear to be that much in the way of revision levels written on the board other than WR@P FULL 0028.3 there is also a number 1542329 written on the edge next to this info outlined by a box T110 94V 0
    #189640
    The Indest Company now have a maximum repair charge scheme. You would need a new module and eeprom which will cost you more than the maximum repair charge.
    Simon46
    Looks like waterleak /condensation on board has caused the tracks to join. Needs to be identified first.
    Regards
    Simon
    #189642
    HankMcSpank
    Thanks guys….was pretty desperatre (wife was faced with going to one of those awful High St Laundromats!) so I took a flier & cleaned up the area & remade the track by soldering/bridging the break with a little bit of wire (having read of someone doing similar with the same machine) – it works now!!
