ASKO w660, no display on LCD panel
Home Forums Public Support Forums Help And Support Washing Machine Help Forum ASKO w660, no display on LCD panel
Viewing 6 posts - 16 through 21 (of 21 total)
  • #380198
    colint
    Re: ASKO w660, no display on LCD panel
    Sorry — just realised that I must have removed the bit when writing my original post where I mentioned that I’m currently living in Australia! :rolls: By local agents, I meant the Australian agent, who told me that the machine’s likely to be 10 to 12 years old.
    #380199
    cockney steve
    Have you considered the harness? It’s spent ~ 20 years being jiggled around and an internal wire-break is a distinct possibility…..same happens in the motor-trade,-Central-locking /mirrors/windows…dodgy multipin-connector or broken/chafed/shorted wire….Driver’s door is favourite as it gets most use.
    So, try board-connectors,test the harness AND GIVE EACH WIRE A GOOD WIGGLE AND TUG if no joy, consider a local indipendent TV/Electronics repairer…..there are trade firms that will repair boards, you’ll have to google.
    IMHO, it’ll be a super machine when running and when it’s eventually dead, you’ll be convinced the ISE is it’s only worthwhile successor.
    #380200
    Even though he would have to relocate to the UK to buy an ISE. 😉
    #380201
    colint
    cockney steve wrote:IMHO, it’ll be a super machine when running and when it’s eventually dead, you’ll be convinced the ISE is it’s only worthwhile successor.
    Thanks for the suggestions Steve — I think I’ve found a repairman who reckons he could find a used control board rather than fitting a brand new one. He also reckons the door lock will need replacing too. Although it seems to be working OK, it did seem to be the start of the trouble… 🙁
    Colin
    #380202
    cockney steve
    Blimey! Jim, I’ve turned into a senile old git! 😳
    Jumped straight in without bothering to see where the topic originator resides.
    my excuse….old website had a separate bit at the bottom for furriners.
    My No. 1 son is now saving for an ISE dryer to complement his ISE washer when the present dryer croaks.
    #380203
    colint
    cockney steve wrote: Jumped straight in without bothering to see where the topic originator resides.
    😀 My fault for the confusion actually, I used this forum a few times before moving to Aus, and started this thread without mentioning my current location. I also only updated my profile location recently.
    There is still an Aussie section, but I haven’t had any replies there yet.
