Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › AWD12 bearing job?
- This topic has 22 replies, 5 voices, and was last updated 17 years, 11 months ago by
T_i_m.
April 27, 2008 at 6:02 pm #36325
T_i_m
ParticipantHi All,
So, the ‘Ariston Margherita 2008 AWD12 Advantage’ (to give it it’s full washing machine club of Italy title ) has just thrown it’s bearing(s). 🙁
Is this an easy job (for someone who has done similar easily on an AEG Lavamat 6100 Digitronic) please?
Should I strip it down first and *then* order the bearings, in case anything else was taken out in the crash?
All the best ..
T i m
p.s. It says model No 26096B but should it also have a magic code number somewhere please?
April 27, 2008 at 6:18 pm #250551Penguin45
ParticipantRe: AWD12 bearing job?
I’d get the cross piece out first and check the condition of the shaft. If it’s damaged…….. It’s a sealed tub! :rotfl:
What happened with “The Other One”?
April 27, 2008 at 6:24 pm #250552iadom
ModeratorRe: AWD12 bearing job?
Looking at the diagrams it is the one with the bearings in a spider at the back of the drum.
Not that bad a job as long as the drum shaft is not damaged. Worth checking it out first. If the shaft is badly damaged then it would need a complete drum assy, almost £90 ex vat. 😯
Two different types of spider and also different bearing sizes so all in all, best strip it down first.
Removing the nut that secures the pulley is often a bit of a pain, a bit of heat then a few sharp blows with a knockometer usually breaks the loctite seal before your torx bit snaps. 😉
Oh BTW, make sure you have plenty of plasters or bandages handy.
Evening Chris. :waving:
April 27, 2008 at 9:34 pm #250553T_i_m
Penguin45 wrote:I’d get the cross piece out first and check the condition of the shaft. If it’s damaged…….. It’s a sealed tub! :rotfl:
No it’s not is it .. not another one?!?.. 🙁
Well I did the AEG from up the back so I know the routine if so.
What, talk about that here and get told off .. I down’t fink so!
All the best ..
T i m
April 27, 2008 at 9:43 pm #250554T_i_m
Ah ok, well I’m not sure I’d want to spend any decent money on it, considering what it is etc.
Ok, will do. I nearly started it tonight but that would be 3 machines in bits .. !
Yup, and nothing much to lose using a bit of heat ..
Yeah, I read that here somewhere … I actually have to thin rubber gloves with fabric backs that are supposed to be cut resistant.
All the best ..
T i m
April 27, 2008 at 10:05 pm #250555iadom
Told off, :rolls: Nay, there are a good many people longing to know how the project is progressing. 🙂
April 27, 2008 at 10:40 pm #250556T_i_m
Well, seeing as you asked ..
I have had the tub in half, cleaned everything up, new bearings and seal fitted (backed by white waterproof grease), pulley back on and was just considering the best way to joint the two halves back together again.
I was intending doing it yesterday but unfortunatly the wifes mother died.
In light of the Ariston exploding tonight, I decided to use some 12mm diameter neoprene, wedged deep into the std seal groove and then the joint, (bolt holes spaced apart with ss washers to replace the material sawn away when the tub was split) additionally sealed using some CT1 and bolted up.
Tomorrow I’ll put it all back together and let you know how I get on.
All the best ..
T i m
April 27, 2008 at 11:52 pm #250557Penguin45
Sorry to hear the news, T_I_M – update us when you’re ready. Iadom’s right – we are actually quite fascinated.
April 28, 2008 at 6:26 am #250558T_i_m
Penguin45 wrote:Sorry to hear the news, T_I_M – update us when you’re ready. Iadom’s right – we are actually quite fascinated.
Ok, thanks on the MIL. She was a good ole stick but smoked most of her life. A life that may have been quite a bit longer if it hadn’t been for the emphysema. It finally happened very quickly in hospital and my wife and her eldest were there at the time. May she now RIP (peace without the oxygen machine and constant coughing).
Ok, I hope to pop the machine back together today ..
I noticed the door rubber is quite stained and reading here it seems there isn’t much you can do about it (short of buying a new one). I may well do that once I know it’s working again.
All the best ..
T i m
April 29, 2008 at 3:01 pm #250559T_i_m
So,
Daughter and I have pulled the AWD12 out and put the ZWF1431W in it’s place.
I got her to start opening the Ariston re fitting new bearings and (compared with her recent and only experiences so far with the Zanussi) thinks it’s a POS.) 😉
So, as it was working ok just before the bearings failed (and that’s potentially all it needs atm), would it be the right thing to do, to offer it here, complete or as spare parts .. a bit like Freecycle but with a more whitegoods focus. 😉
Failing that,, do you think anyone would love their AWD12 enough to want to buy bits for it off eBay etc?
All the best ..
T i m
April 29, 2008 at 9:45 pm #250560madrat
That sealent is the Dogs dangly bits 😯 how much is it? cant find any mention of price on there web site.
April 29, 2008 at 10:14 pm #250561kwatt
KeymasterI have requested a sample as I’ve not come across it before.
We’ll test it and I may send some (if they send me some) to certain flightless bird to evaluate. 😉
April 29, 2008 at 10:17 pm #250562madrat
April 29, 2008 at 10:18 pm #250563T_i_m
madrat wrote:That sealent is the Dogs dangly bits 😯 how much is it? cant find any mention of price on there web site.
I paid about 8 quid for it and it’s available from ‘your independant builders merchant’ … for me that was City Electrical Factors. Apparently you should also use their solvent for ‘tooling off’ .. being as it sticks to wet fingers ..!
But if you give the distributors a call I’m sure they will tell you:
Email: info@ctechuk.co.uk
Telephone: 01842 828230No connection etc.
All the best ..
T i m
April 29, 2008 at 10:20 pm #250564kwatt
KeymasterHe does photos and stuff! Plus he knows a bit about sealing stuff that really, shouldn’t be sealed or attempted to be sealed.
But if they give me more than a couple of tubes it’s open season. 😉
(p.s. NOT open season on penguins!)
