Beko concrete bolts sheared off. How extract from plastic?
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Beko concrete bolts sheared off. How extract from plastic?
Viewing 15 posts - 16 through 30 (of 39 total)
  • #170781
    Re: Beko concrete bolts sheared off. How extract from plasti
    Halfords sounds like a good idea to me Mike.
    Kevin
    #170782
    Got the extractors. £8 the set – this job’s getting expensive already! In a way I hope they don’t quite work so I can try out my other ideas which I’m still brewing.
    Mike.
    #170783
    But consider for another £3.00 you can now stock the bolts and do a 1st time fix the next time around… paying for the tool in one hit.
    Kevin
    #170784
    kheath wrote:But consider for another £3.00 you can now stock the bolts and do a 1st time fix the next time around… paying for the tool in one hit.
    Kevin
    Kevin, Where can I get two bolts for £3 ❓ as Seme had to make a “special enquiry” of it (= delay, delay) and Connect has them at £2.55 each.
    Cheers,
    Mike.
    #170785
    Last one I did, I went to my local “proper” irommongers and bought some rather more substantial ones for about 13p each. Bit of imagination and lateral thinking helps no end.
    The extractor kit is an equipment purchase, so is deductible as an expense against you tax bill. Don’t mess about with it, do it right.
    Penguin45 wrote:lateral thinking helps no end…..
    ……..deductible as an expense against you tax bill. Chris.
    Thanks for that Chris, I will remember to lay the machine on it’s side.(Be careful with the lateral thinking when Martin’s around though, he might tell the sheriff 😆 ).
    As for deductibles, don’t worry, even a proportion of my internet connection fees go in there and so will the 13p bolts.
    Mike.
    #170787
    agro
    Done a beko tub today With the bolt snapped under insur.Glad they are cheapies Keeps me in a job Who needs enemies when we have Beko Little tip l use a little silicone in the hole helps, done loads and they dont come loose again .Well not yet anyway
    #170788
    Thanks for that agro, had been thinking of using Debor in the hole.
    But I may have left it festering too long. Rang customer just now and she’s thinking about new 🙄 . I must have given her a too negative impression of the chances of a successful fix when I first saw the problem.
    (Maybe I do need that NVQ module in customer relations). Await the judgement of husband with whom problem must be discussed again.
    Good thing I got my call-out charge up front!
    Mike.
    #170789
    So you won’t be taking a complete drum assembly there on your pushbike then? That would have been entertaining to watch 😆
    #170790
    Most awkward thing I’ve had to do on the bike so far is transport a complete Indesit inner drum w. spider 2 miles including through town centre. Couple of bungee cords held it very well to my rear carrier above my tool bags. Thinking I might get my bike signwritten to take advantage of advertising potential.
    I have on a couple of occasions used a taxi (charged to customer) to transport a complete drum assy when too little space to work on customer’s premises.
    I reckon every mile I cycle saves me 25p on vehicle expenses not to mention the saving in not having a garage. I also get fresh air and exercise which other people pay a gym subscription for. Recent cold weather and heavy rain has tested my resolve but I just don’t feel inclined to give up my economic freedom from the car and oil industries. (A freedom I have enjoyed for three and a half years now).:wink:
    Mike.
    #170791
    EFS
    If you don,t approve of oil companies why not invest in an old LDV and run it on filtered chip shop oil. 😆
    #170792
    Hi EFS,
    I think you’ve missed my point. I LIKE fresh air.
    😉 Mike.
    #170793
    Here you go Mike, this’ll solve the bulk problem:
    You could probably even get an ISE on there.
    gegsy
    Is that you Mike ??
    Penguin45 wrote:Here you go Mike, this’ll solve the bulk problem:
    Chris.Thanks Chris, that looks super for when I move house.
    Actually though I don’t have a problem with bulk. Most of what I need is inside my skull. (Although there are times when it seems a bit gunked up in there) 😉
    Mike.
