BEKO control module
  • #91259
    BEKO WMB61431W, need part number for main module please.
    Re: BEKO control module
    Should be 2826920510.
    Ta, not ben out to it yet but the small cul de sac the customer lives in has apparently been hit by a massive power surge. Taken out virtually all connected electronic devices in every house, phones, TV, audio, washers, refrigeration etc.
    Can’t see it in the store, is it stocked?
    #447577
    No use on it as yet Jim but roughly, £55-65 or thereabouts.
    OK, will go and check it out first.
    #447579
    hyg-dip
    In stock at AWS appliance spares
    retail price of £49.99
    #447580
    Thanks, will make a note of that.
    hyg-dip
    Hi Jim
    Andy advised no account required, but can you please provide your contact number or ring AWS on 01603 412324 in order that we can progress the module for you
    Thank you
    Paul
    AWS
    #447582
    Thanks Paul, will ring you now.
    It was a bit like a disaster zone in this small close of about 20 houses. 8 or 9 British Gas vans there fixing all the broken central heating units.
    The washer I went to had a totally fried main module, also taken out the plug fuse. The power surge had also damaged 3 TV’s, the Sky box, telephones, microwave and burnt out the motor to her Stannah stair lift. :zap:
    #447584
    Lawrence
    Slightly off topic ,but that reminds me of a farmhouse I went to that was fed by its own supply from the grid ,the power surge had blown every appliance but had also melted the wiring in the wall.all you could see were strips of scorched cabling bursting through the plaster
    #447585
    hyg-dip wrote:Hi Jim
    Thank you
    Paul
    AWS
    Part arrived this morning, excellent service. :tup:
    #447586
    hyg-dip
    Hi Jim
    Thank you..
    Glad we could assit
    Kind regards
    Paul
    #447587
    Simon46
    Expect multiple jobs in the road!
