Home › Forums › Public Support Forums › Help And Support › Tumble Dryer Help Forum › Beko dryer DTKCE80021W
- This topic has 16 replies, 2 voices, and was last updated 1 year, 11 months ago by
seanbabtiste.
April 27, 2024 at 10:53 am #102725
seanbabtiste
ParticipantHi All , Im struggling to find a part and a price for a Mains Filter Suppressor for the above dryer, can any one Help Tia
April 27, 2024 at 11:37 am #490189electrofix
Moderatoram struggling with that too
let me have the complete serial no
they dont go often what the fault your getting ?
April 27, 2024 at 2:54 pm #490190seanbabtiste
Participanthi , Tripping the electric , s/n 22-202911-02 or 7182483000 cheers
April 27, 2024 at 3:34 pm #490191electrofix
Moderatorand have you tried disconnecting the wires after the suppressor to make sure its that
April 27, 2024 at 3:41 pm #490192electrofix
Moderatorsuppressor part no should be either
1883880500
or
1883880600both should fit but the one ending 500 is the one i would look for
April 27, 2024 at 3:42 pm #490193seanbabtiste
April 27, 2024 at 3:43 pm #490194seanbabtiste
Participantnot sure where you mean to disconnect, im presuming also that the black box in pic is the supressor? thx
April 27, 2024 at 4:02 pm #490195electrofix
Moderatorall the black box is is a connector and unless its burnt its not faulty
suppressor is inside the steel box
had one the other day and it was the heater causing the problem
disconnect the white connectors in your pic and try it
it wont heat but if it doesnt trip it could be the heater. if heater gets wet it will cause same problem
April 27, 2024 at 5:11 pm #490196electrofix
Moderatorunpug the 2 white connectors
plug it in and if it trip its not the heater
if it does not trip then the heater is where you look next
April 29, 2024 at 6:27 pm #490197seanbabtiste
ParticipantSo , it looks like it was a slightly overheated/burnt connector as in the pics (the black box) i still cant see the mains filter though???
Thanks Dave for the knowledge its appreciatedJune 2, 2024 at 4:41 pm #490198seanbabtiste
ParticipantExperts please
Mmmmm, ok apparently the dryer has a leaky earth? according to the electrician that tested it, so using google one prong on the earth prong of plug and the other on the metal back frame of dryer and meter on Ohms, am i right so far? but which Ohm settiing 2M, 200k, 20k or 200, and which readings should i be getting for good and bad?, i should also point out at my house the dryer could run for a month solid and not trip but at there house it trips in every socket? I should add ive changed the plug for a brand new one, instead of the plastic sealed type
TiaJune 2, 2024 at 4:54 pm #490199electrofix
Moderatorone prong on live and neutral the other on the casing
2M scale minimum
June 2, 2024 at 6:10 pm #490200seanbabtiste
ParticipantOn the 2M its black prong on live+neutral and red on back casing and reading point.558 hows that good or bad?
June 2, 2024 at 7:00 pm #490201electrofix
Moderatorshould not get anything
disconnect heater and see if it goes
June 2, 2024 at 7:31 pm #490202electrofix
Moderatorwell either will do
you are testing resitance from live or neutral to earthyou should not get a significant reading on either
