beko excellence WMB91242LC no data shown for programmes
Home Forums Public Support Forums Help And Support Washing Machine Help Forum beko excellence WMB91242LC no data shown for programmes
Viewing 15 posts - 1 through 15 (of 21 total)
  • #102730
    Aortic Mark
    Sudden onset failure of machine to show programme data as dial is turned, save for two wash settings. Machine does not start to run on any of the selections. Main Module pcb looked sooty, especially around one particular microchip; but when soot removed, no distortion or damage is visible. Rest of machine looks fine. Is it worth investing in a new module? Bought second hand, but trying to be green, so don’t want to give up too easily and the machine was running perfectly until it wasn’t.
    #490221
    which programmes seem to be visible
    was one of these programmes the last one used ?
    Aortic Mark
    Hi Dave,
    Down to one programme, and almost certainly the last one used – mixed fabrics, 40°C, 1000 spin; could even be the ONLY programme ever used in our household!
    Regards.
    Mark.
    #490223
    its not had the child lock activated by accident has it ?
    Aortic Mark
    Hi Dave,
    That would explain everything and was not a function I was aware of; the machine did not come with the manual and I neglected to download it. I will check that as soon as I get home.
    Thanks.
    Mark.
    #490225
    Aortic Mark
    Hi Dave,
    Just checked the machine and, unfortunately, the child lock was not on, but it can still be activated and deactivated on any of the programme selections.
    Regards.
    Mark.
    #490226
    ok this unit seems to have a seperate programme selector sw
    https://shop.ukwhitegoods.co.uk/2827…elector-switch
    check the wire going to this have not becomes dislodged either end
    Aortic Mark
    Will do, but it might take me a couple of days to get round to it. Thanks for this advice.
    Mark.
    #490228
    Aortic Mark
    Whilst I get round to tracing the wires, this is what I see when I turn it on. The yellow arrowhead flashes “ready” on all of the settings, it just was not captured in the second photo; pressing “start” has no effect. As you turn the selector, absolutely nothing happens (arrowhead is blinking) until you reach Mixed Fabrics, when those numbers appear.
    #490229
    press and hold start button as if your cancelling the programme
    see if that does anything
    the selector or the wires too it could be faulty
    well if you have not done already
    remove each connector and put it back twice
    if the contacts are dirty it will clean them
    have you tried cancel button ?
    long shot
    check motor carbon brushes
    Aortic Mark
    Unplugging, then replugging plus cancel button makes no difference.
    How does the motor contacts affect the programme function?
    #490233
    Aortic Mark
    Are the brushes accessible with the motor left in situ?
    #490234
    tilt the machine back 45 degrees against a wall or similar and climb underneath
    on some machines unit wont function if brushes lose contact with armature
