Beko PCB
  • #103398
    dopper
    Fitted a new main pcb to a beko WDIR7543101 which was dead. it comes on now but when i press start it bleeps an the start button doesn’t light up and wont start. not had this before and fitted many.
    checked the child lock and door lock
    Any pointers?
    #492987
    i know what Beko are like
    let me have
    full serial no and the part no you have fitted
    dopper
    Hi Dave s/n 20-800040-01 WDIR7543101 prod code 7165141300 main PCB part number 2437301131
    Paul
    #492989
    ok part no seems correct
    assume you have tried or checked child lock
    what was the reason for changing the board. assume from above it was no power from above
    did you check D7 on the board for short circuit. very common reason for no power on these boards
    dopper
    Hi yes no power its not the child lock but its like when the child lock is on.
    Did a code check and it came up e23 then worked but then did the same after that.
    Going to take it back off to make sure all the plugs are in tight.
    do you think it could be a dodgy board?
    #492991
    so its not no power, it powers up but wont start. was that what the old board did ?
    E23 is a door lock error
    does it do that all the time ?
    dave
    #492992
    dopper
    Hi old board was no power so dead, new board power all lights work but start. i will check the door lock
    Cheers
    #492993
    also check D7 on the old board
    common fault and very cheap to fix
    dopper
    Hi so update is if i put it in test mode then turn it off at on/off then back on, it works on a programme, the start button works, but next time the start button bleeps and work start, Strange one?
    #492995
    suedehead1
    Hi, I had the same problem 2 different boards 2 different types of door lock. I actually put a solenoid operated door lock on instead of the bimetal and it cured it.
    #492996
    suedehead1 wrote:Hi, I had the same problem 2 different boards 2 different types of door lock. I actually put a solenoid operated door lock on instead of the bimetal and it cured it.
    cant see how that works as the board deals with each type of lock differently
    if you put a solenoid lock on a board that is meant for a ptc type the solenoid coil would not cycle properly and the coil is also not meant to be energised for long periods so I would expect it to burn out
    suedehead1
    I ordered the pcb for the machine and when i fitted it it lit up but it kept saying the door wasnt locked old style door lock, I fitted a solenoid door lock
    and it worked. pcb was wrong one for that machine seemed to be 2 different versions.
    #492998
    suedehead1 wrote:I ordered the pcb for the machine and when i fitted it it lit up but it kept saying the door wasnt locked old style door lock, I fitted a solenoid door lock
    Beko often change boards by serial no so it may have been for same model but the may have changed board and lock on a later machine
    can see that happening and I have looked up Beko parts that change number if add serial no
    suedehead1
    possibly the machine had been reconditioned it was in rented accomadation
    #493000
    suedehead1
    i have had a couple of problems with Beko dryer boards where connect list different boards for the same model.
