Beko WMA510W turns slowly instead of spinning: SOLVED :)
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Beko WMA510W turns slowly instead of spinning: SOLVED :)
Viewing 4 posts - 16 through 19 (of 19 total)
  • #339984
    Springnuts
    Re: Beko WMA510W turns slowly instead of spinning: brush len
    Hi everyone and many thanks for all the info.
    Just washed a few towels and they spun successfully, 8) so it does sound as if the unbalanced load sensor was just protecting the machine.
    I am a bit 😳 as there is a sticky about this which specifically points out that:
    … a single heavy item may never spin as it will always be unbalanced.
    Now, I am off to Afghan in a while …. don’t want the brushes wearing out while I am away. Anyone any idea of how long I might get out of the remaining 10mm of wear?
    Thanks again 😀
    Springnuts.
    #339985
    quickwash
    Re: Beko WMA510W turns slowly instead of spinning: SOLVED 🙂
    I shouldnt be 😳 as you definitely wont be the last 😉
    Best Wishes
    quickwash :plug:
    #339986
    odom
    Springnuts wrote:Now, I am off to Afghan in a while …. don’t want the brushes wearing out while I am away. Anyone any idea of how long I might get out of the remaining 10mm of wear?
    Depends how often you use the machine 😉 but for normal usage 2-3 years should be about right. New they are about an inch long.
    #339987
    Springnuts
    Thanks odom,
    Well I hope I am not there that long!!! 😆
    Regards and thanks again everyone,
    Springnuts.
