Beko WTL84141W
  • This topic has 15 replies, 3 voices, and was last updated 2 years ago by euro.
  • #102634
    euro
    Its a 2023 model thats all i can see as label is kind of damaged, the fault was not draining so thats been sorted but its finishing a wash and the door lock keeps on clicking, it will stop when you open it but odd time keeps doing this for a short time, they say its tripping electrics but cant say if thats after wash is finished, any suggestions to why this is happening.
    Andy
    #489759
    cant see any tech problems about the lock apart from an NTC problem can stop door opening at the end
    does not seem to fit your problem but measuring or disconnecting NTC
    euro
    Thanks Dave, its a strange one, i put it on a drain and spin and at end door opened and that was it, next a rinse and spin and it started with the lock clicking for about a minute or so then it stopped, short cycle it done same, even when door open it clicks like mad.
    #489761
    is it just coincidence the spin only was ok or is that ok all the time
    euro
    By what they said it will do the wash ok its only at the end the door locks acts this way, the initial fault was draining intermitantly but that was a hair clip floating about in the pump along with white paper towel (its in a hospital unit), one said it was tripping the electrics but not if it was during wash or at end, you have experience of these places where one says one thing then another says something else;):D
    #489763
    yes had lot of them including getting called out to machine only to arrive to find it in use by another member of staff who knows nothing about a fault on the appliance
    euro
    Very true what you say there, one does not know what other is doing, even had machines where i put a a4 sheet on it with tale over front saying do not use only to find when going back in its been taken of and being used.
    Since this one has happen have got another couple of bekos doing the same thing and one needing a heater, would you have part numbers please for heater, door lock and the ntc please.
    Andy
    #489765
    can do but
    with the beko site from the model above i can get a part no but if i put the serial no in it may change
    so if you dont want to take a chance let me have serial
    without serial i get
    heater 2882601600
    door lock 2849660500
    ntc looks like its on the heater
    euro
    Thanks Dave, the label is damaged and all i could see was 23 and rest is of, is this ntc falt something that affects alot of the latest beko models as got another one but different model doing this
    Andy
    #489768
    nothing in the tech
    have you measured the ntc ?
    euro
    Not yet as it only came in today, it might be a wasted journey as was at it a few weeks ago and none of the staff had problems with it being noisy, i can remember it was a similar model and age to this one i have got on the go, job just says not always able to lock door
    Andy
    #489770
    well that could be mechanical or electrical
    matrixresonator
    Have you meggered the element, I’ve seen a few machines where slight earth leaks, while not causing the RCD to trip, will play up with the door lock.
    #489772
    euro
    A new element and ntc solved the problem
