Bizarre issue with fridge
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Bizarre issue with fridge
Viewing 6 posts - 16 through 21 (of 21 total)
  • #463759
    think you just proved it. although you can never be 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} certain I think you could be in the 90’s with this one
    menderman
    Right. Continuing saga.
    I have received my order from CPC but the numbers on the new stat are not K59 L4106 which is what was stated on the website.
    But the number is K59-P4967
    The other numbers are
    K59-P4967
    19-23-02S
    H2622.
    The numbers on my original are
    K59 L4106
    96-4-21P21
    H2622
    So should I send it back or is it the equivalent replacement I need, the printed number on the packaging that I have not opened is C00261055
    #463761
    well that part no ( c00261055) is listed by my supplier as
    K59-P4967
    so it looks like its an equivalent supplied by the manufacturer so should fit
    menderman
    thanks — yet again Dave. i will report back when fitted. One thing i noted when i last replaced the stat is that to get the correct temp the dial had to go up to 7 when before it was always around 4 if I remember correctly. My suspicion is that it was never the correct replacement
    #463763
    menderman
    Just wanted to report back to say that the new sat seems to be working great for 3 days and the fridge dial is back down to 3 like it used to be. Thank you Dave for your expert help with this – you have saved another fridge from the landfill.
    #463764
    menderman
    Well here I am again.
    Same fridge almost exactly 5years to the day since my last post. The fridge suddenly froze everything in the lower section so I turned the stat to zero and back to 3 1/2 and since then its been working fine. The odd thing is as I mentioned 5 years ago since i fitted that new stat I had to have it set on 7 which was higher than my original stat ever needed but now all of a sudden 3.5 is what it needs. – Any ideas.
