Blomberg WM 1301BB No Power Light
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Blomberg WM 1301BB No Power Light
Viewing 7 posts - 16 through 22 (of 22 total)
  • #261764
    helo_75
    1L = live
    2C = common
    3N= neutral
    ill try and explain – 1L should be the live from the timer, 3N should be neutral.. now when the door is closed, and the programme selected, and the on of swithc pressed, 1L should become live, and a coil in the interlock , (as long as 3N ISneutral) should engage, and lock the door, supplyin a live back through the lock via 2c to tell the timer the door is locked and will start the program
    im not the best at explaining things on here, but i hope you get the gist of what im saying?
    yes, i got your mail, but you say youve ordered a lock from store, and i no longer have blomberg manuals on my laptop ( theyre pretty old now)
    #261765
    Park
    Re: Blomberg WM 1301BB No Power Light
    Good enough explanation for me, thanks.
    I have some practical electronic & electrical knowledge, can interpret circuit diag, but will be careful. Any idea how to get tech manual.
    Still waiting for the spares.
    Regards.
    #261766
    helo_75
    ill check the office database in the morning, if its still available, ill send you a copy…
    #261767
    Park
    will appreciate it.
    #261768
    Park
    Lock seemed to be the culprit. Atleast the WM has got some life now. Does the prog control dial knob slide in only one fixed or it will slide in any position. Normal cotton position is now spin position ! Do you think I have the dial in wrong position ?
    Now I will go and tide up the soldered wiring on the module’s burnt track .
    Any news about tech manual please.
    #261769
    Park
    Been away but now back.
    The prog is not working as indicated on the dial ! On normal spits out the water as soon as it fills up twice. Then takes the water again goes through ok but ends the cycle in about 15 minutes incl spin, rather than 59 min it used to take.
    Any clues folks ?
    Thanks.
    #261770
    helo_75
    yup, the timers mullered
    not cheap at all, if you can still get em
