Bosch D/W no heat?
Viewing 7 posts - 16 through 22 (of 22 total)
  • #444427
    Re: Bosch D/W no heat?
    steveDAS wrote:I have to give them a call and get better discounts as they want to charge me 56.86
    ……and to add to the mix of random pricing. If you bought direct from BSH with a 10{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} trade discount that part becomes £47.16.
    #444428
    timdowning
    Good luck.
    If my prices go up I will blame you.
    #444429
    Steven
    Part number for these comes listed 00651956 retail £120? plus you mention you can take out from side without removing tank /base? on full size ones I’ve seen it looks as tho you have to remove jubilee clip which is facing the wrong way and the height size shape of motor you can’t pull out not enough access?
    #444430
    timdowning
    Done loads of these just with the door panel off & then front panel.
    Makes it a lot quicker especially on integrated versions.
    The old motor just squeezes through at the right angle. The new motor comes with a thin jubilee clamp which can be tightened with a long thin screwdriver, if the the clamp is positioned to the left side of the sump.
    The old motor can just be twisted off the hose, no undoing required!
    #444431
    I’m thinking the revised part, and its price, have since made the whole issue BER.
    #444432
    Martin wrote:I’m thinking the revised part, and its price, have since made the whole issue BER.
    Which is the reason my customer decided to bail out. 😉
    #444433
    timdowning
    £50 or £70 trade for the motors depending on which one we agree on…
    £60 labour ex VAT for 30 minutes work.
    (£80 labour ex VAT for the integrated ones but still 30 minutes work)
    No need to do any writing off.
