Bosch d/w sgs55c02gb/01 check water light
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch d/w sgs55c02gb/01 check water light
Viewing 2 posts - 16 through 17 (of 17 total)
  • #316662
    nomadPaul
    Re: Bosch d/w sgs55c02gb/01 check water light
    Martin wrote:
    gegsy wrote:
    “When installing the flowmeter, ensure that the direction of flow is correct. The flow sensor may have a maximum incline of 30 degrees to the left only”
    Doh!…..:oops:
    I should read service manuals more thoroughly.
    Ha ha ha , at least you’ve seen the error of your ways Martin 8)
    #316663
    grazzamongrel
    Just to let you all know put new float chamber on and problem solved and cleaned hose from there to sump as a precaution as it was slightly gunked up. Many thanks for all your replies though they were greatly appreciated
