Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Bosch dishwasher not heating up – unless I open the door!!!
- This topic has 16 replies, 4 voices, and was last updated 11 years, 5 months ago by
markjgobrien.
October 28, 2014 at 3:51 pm #82804
markjgobrien
ParticipantHi everyone,
I have a bosch classixx maxx freedom performance dishwasher and it’s a strange one. The dishwasher fails to heat the water up if I leave it alone, however… as soon as I open the door and then close it again, bingo – it heats up. This means that it only washes properly if I open and close the door after it fills up for each cycle that heat is needed (so not the pre wash). If I leave it alone then it will run all day!
The question is, what impact is opening the door having on the programme? I am literally opening and closing the door in about 2 seconds. Initially I thought it wasn’t getting enough water in, and would add a jug or water myself once the main cycle had started it. I thought I had it all worked out and replaced the inlet valve, but I am still having problems! The dishwater wasting heating up because I added additional water, it was heating up because I had opened the door! Bizarre!
Can anyone help? Thanks!
October 28, 2014 at 5:49 pm #420862Martin
ParticipantRe: Bosch dishwasher not heating up – unless I open the door
I’m more than confident someone can help you out. What’s the model number of this Classixx by the way as Bosch made 1000’s of variants?…
October 28, 2014 at 7:43 pm #420863Andy jones
Possibly a chaffed wire in the door loom
October 28, 2014 at 8:02 pm #420864Martin
Andy jones wrote:Possibly a chaffed wire in the door loom
There’s a good chance it’s a 45cm machine Andy so they’re not known for wiring harness probs.
I cannot visualise anyone opening and closing a dishwasher door every few seconds in order to get it to heat. Fairy liquid and a wash bowl has got to be a more effective alternative, surely. :clown:
October 29, 2014 at 12:31 pm #420865markjgobrien
Hi guys,
Thanks for the replies so far! Ok, I have taken a picture of it so hopefully you’ll have a better idea of what it is!
Any ideas?
October 29, 2014 at 12:36 pm #420866markjgobrien
The dishwasher does get nice and hot once I have opened the door – steam rolls out so I think we can rule out any local problems with the heating element. The inlet valve has been changed so it’s highly unlikely to be that either.
The question is, exactly what triggers the heating elements to kick in? Is there some sort of pressure switch and can opening the door influence it?
October 29, 2014 at 12:47 pm #420867Martin
markjgobrien wrote:Thanks for the replies so far! Ok, I have taken a picture of it so hopefully you’ll have a better idea of what it is!
We guessed already what it is, what we don’t know is what the MODEL NUMBER IS..? It would help a whole bunch if you could tell us….. 😉
October 29, 2014 at 12:56 pm #420868markjgobrien
Ok, it’s quite hard to read but I think it’s: sgs43c12gb/16
October 29, 2014 at 10:32 pm #420869lee8
Check water pressure/level. When you open close the door air is trapped forcing water into the appliance. You may want to check microswitch on element and water level via the flow meter, possible too little is entered, units believes it’s correct but not enough has filled for heater protection to actuate until you open and close the door forcing the water pressure down into the sump.
October 29, 2014 at 11:27 pm #420870markjgobrien
Thanks Lee. I’m running a main wash right now – I switched the dishwasher on and waited for the pre-rinse cycle to finish (15 mins), I then let it run for a further 20 mins or so on the main wash and then opened the door to see if there was any heat… stone cold. I closed the door and after just a couple of minutes opened it up again, it was already getting hot.
In order to check the parts you have mentioned, do I need to remove the side panel? How do I get access to these parts? It seems more and more likely that there is some sort of pressure issue… but are we ruling out any sort of electrical fault? When I open the door I am breaking a circuit, right? That then stops the dishwasher until I close it again, causing it to resume. Is it at all possible that something happens whilst the power is off? Do any of the sensors/valves/switches get reset?
All your efforts are great appreciated – thanks!
October 30, 2014 at 1:05 am #420871markjgobrien
Ok, I’ve taken the side panel off and here’s a few pictures… it all seems pretty clean to me!
October 30, 2014 at 1:06 am #420872markjgobrien
Again, slightly closer.
October 30, 2014 at 1:09 am #420873markjgobrien
There seems to be a bit of a build up just under these sections at the bottom of what I presume is the pressure chamber – perhaps these need to be cleaned out? If so, how do I detach the pressure chamber?
October 31, 2014 at 1:23 pm #420874markjgobrien
Martin wrote:
markjgobrien wrote:
Thanks for the replies so far! Ok, I have taken a picture of it so hopefully you’ll have a better idea of what it is!We guessed already what it is, what we don’t know is what the MODEL NUMBER IS..? It would help a whole bunch if you could tell us….. 😉
Hi Martin, I’ve attached a few photos – everything looks clean to me. What do you think?
October 31, 2014 at 3:31 pm #420875Martin
I’m thinking I would like to check the main PCB for a burned heater relay terminal. Also, when it stops filling, how much water is in the tub?
