Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Bosch Exxcel SGS43EO2GB/43 Stops During Cycle
- This topic has 20 replies, 4 voices, and was last updated 15 years, 2 months ago by
magnumm44.
February 18, 2011 at 7:53 pm #343053
magnumm44
ParticipantRe: Bosch Exxcel SGS43EO2GB/43 Stops During Cycle
Hi again CJA,
There are only the 4 buttons on the control, Auto 55-65deg, Eco 50deg, Quick 35deg & pre-rinse. I would say the Quick wash temp is as hot as the others, yet the time is less at about 37min. The other washes seem OK temp wise. Well I suppose it gets the dishes cleaner in less time.
Just one other thing (I’m probably throwing too many balls in here, sorry), about my last post. When I said that aftyer applying solder to the pcb the quick wash went OK, actually, it didn’t. It did not empty. When I did a reset (after restarting it) it empties, so that should rule out a blockage? Greatful for any advice.
Bob
February 18, 2011 at 8:33 pm #343054CJAPeterborough
check your manual -you can download it from the bosch support site
There is a key combination that toggles the intensive drying on/off.Cant comment on the not emptying -there shouldnt be water above the
the filter tray after it finishes if there is then it could be a host of things.
Weak pump/restricted impellor or you have an overfilling problem.Have you cleaned out the sump hose and pressure chamber?
February 18, 2011 at 9:02 pm #343055magnumm44
Thanks so much for the input, I will look into it next week, busy shooting at the weekend(not animals), looks like the DW has earned areprive from the skip! I’d so love to be able to get it going right, suppose a few days of washing up won’t kill us. Hope you keep a look out for me next week.
Best regards,
Bob
February 22, 2011 at 7:03 pm #343056magnumm44
Thanks CJAPeterborough!
You were correct re the the intensive drying option, so that has put my mind at rest re the quick wash. Re the ‘blob of solder’, I have run 3 washes now all have finished without stopping during cycle, so fingers crossed on that one. Just have to sort out the not emptying problem now.
Today, on a quick wash, at the end I could hear it trying to empty, I could hear a sort of ‘grinding’ sound as if the pump was not functioning properly, not sure. Will clean out all the pipes and things at the side. Let you know what happens.
Bob
February 26, 2011 at 7:41 pm #343057CJAPeterborough
Sound like you need a new pump……either blocked/restricted or loose impellor…
February 27, 2011 at 12:07 pm #343058magnumm44
Thanks CJAPeterborough,
Since last post I ran a full cycle and it stopped a couple of times, yet just a flick of the finger against the door by the control panel and it started, so back to square one with that! There are just too many things going on with this machine, so it’s bye bye Bosch! Thanks for all the input.
Bob
