Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Bosch FL, dispenser and fascia melted, I’m baffled!
- This topic has 20 replies, 8 voices, and was last updated 13 years, 6 months ago by
Twoten.
October 3, 2012 at 8:58 pm #382323
Twoten
ParticipantRe: Bosch FL, dispenser and fascia melted, I’m baffled!
madangler1 wrote:Got to say though with it being rented I’d be very suspicious. People will do anything to get a freebie
Usually when a tenant is after another machine or something else they would be passing comments about the age of the machine and that it’s damaged the washing. They haven’t even hinted at this.
The door seal appears to be OK.
October 5, 2012 at 8:21 am #382324jason1970
The older Hotpoint 95 series were always overheating and distorting the soap drawer, often to the point you couldn’t open or close the drawer properly.
Bosch machines often have thin wires on the NTC. With a heavy load, the drum movement could cause a poor connection if the wire was close to breaking. Testing it empty (if you did?) would remove the movement.
Also if the machine was overloaded, the clothes at the top would be out of the water for a lot of the time with the low level of water used on modern machines.
I would replace NTC and check wiring to it and heater one more time. After that, advise customer uses the machine but with caution???
The job would be no fun if all the jobs were easy! 😉October 5, 2012 at 9:11 am #382325Twoten
Wiring looks OK, it was initially test empty but has been used for at least 6 washes and not given any further problem.
If the information is correct about it happening within about 15 minutes then I doubt it would have been the NTC but I can’t guarantee it was that quick so I think the best option will be replace the NTC as suggested and see what happens.October 5, 2012 at 4:15 pm #382326jason1970
Good luck! Let us know how it turns out, interesting one!
October 22, 2012 at 1:56 pm #382327bryan-206
Did you find any cause for this?
October 22, 2012 at 2:41 pm #382328Twoten
I hadn’t posted an update on this as I have been in China for a couple of weeks.
I have checked with the customer and the machine has worked without any problems since my original visit (3 weeks ago)so I don’t know what the cause of this was.
I am going to replace the fascia, dispenser and NTC and see what happens in the future.
It is possible the damage could have been caused by an external heat source rather than a fault with the machine but there is no way of knowing, the tenant is hardly likely to admit to it.
