Bosch Logixx 7/4 flashing tap icon
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch Logixx 7/4 flashing tap icon
Viewing 5 posts - 16 through 20 (of 20 total)
  • #468843
    MikeTB
    I have a similar problem. I have checked both ends of the hose and both filters are OK
    Today I also noticed that the water level seemed to be far too high, and the foaming symbol appeared at the end of the wash. This seems to suggest the level sensor is blocked, rather than a fault with the triple valve.
    I have no problem working on the machine, but it is installed in a limited space and will be difficult to remove for access.
    I need to be sure whether I need the valve as I don’t want to remove it all more than once.
    #468844
    unless the valve is sticking it cant be a valve fault
    MikeTB
    Thanks. Maybe if I give more information it will help. Machine starts OK and fills correctly for the wash cycle. No alarms.
    The problems only come during the rinsing cycle. While it is filling it starts beeping (each fill), but continues filling to what seems a high level – over half way up the door.
    It continues and eventually completes the wash. Today the tap symbol stayed on, but the last wash it did not.
    There is obviously no shortage of water flow or pressure..From your earlier comments this does seem to be the valve.
    Note that although the machine is fairly old it has never had heavy use, as i used to spend a lot of time away from home.
    #468846
    MikeTB
    Machine still works but during fill beeps and flashes tap light. No shortage of water. Maybe too much. I still suspect the valve as i cannot see level sensor causing this. Valve seems to be easy solution as it just require removal of top cover.
    #468847
    dont know model but if you find the owners manual I think you will find
    if the tap icon is steady its a water problem
    if it flashes it can be anything else
