Bosch Maxx WFL 2450 Acting Strangely !!
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch Maxx WFL 2450 Acting Strangely !!
Viewing 4 posts - 16 through 19 (of 19 total)
  • #173551
    Trilobite
    Re: Bosch Maxx WFL 2450 Acting Strangely !!
    Martin wrote:There is no doubt in my mind that the Programme Control Module is the fault as Gegsy suggests. The replacement costs well justified on this machine which is less than 5 years old after all. (Failures often are usually associated with the appliance being subjected to a damp or poorly ventilated environment which affects the electronic circuitry)
    I would advise getting expert help fitting it and configuring the new Module, see link below 😉
    Please excuse me butting in:
    Why don’t the manufacturers fit the modules into moisture-proof boxes, to prevent corrosion. After all, most vehicle engine-management computers are placed in boxes.
    #173552
    Trilobite wrote:Why don’t the manufacturers fit the modules into moisture-proof boxes, to prevent corrosion. After all, most vehicle engine-management computers are placed in boxes.
    Cost and relative values.
    Car computer £500 – £pick a number
    Car Engine – Couple of grand?
    Bosch Washer £280 – £550 whole thing.
    mickyhayes
    Thanks for all the advice . I took the module out and would you believe it … a dry joint . Probably from the vibrations. Bit of solder and hey presto !! Job done.
    Cheers all !!!!!
    #173554
    mickyhayes wrote:Bit of solder and hey presto !! Job done.
    Clever boy!…Nice one :tup:
