Bosch sealed drum WAA24270
Viewing 15 posts - 16 through 30 (of 42 total)
  • #278370
    Turbo
    Re: Bosch sealed drum WAA24270
    Lets hope the pump needs changing every six month that will teach Bosch a lesson.
    Graham
    #278371
    Madmac
    It is a bizzare bit of design that pump arrangment 😯 i think the bean counters have finally run out of ideas on how to make the front loading automatic washing machine any cheaper to produce, and this frankly silly setup looks like grasping at straws.
    Cant imagine it saves much on material costs so it must be build time it improves..margins must be tight at BSH :rolls:
    #278372
    The old San Giorgio/Ocean machines used to have a pump mounted like that to spray up into the drum. Never worked – always blocked.
    Simon46
    And those wires. Sure to break off at the connector :lesson:
    S.
    #278374
    Madmac
    Simon46 wrote:And those wires. Sure to break off at the connector :lesson:
    S.
    And an easier job than a bearing change it must be said.. one door closes etc.. 😉
    #278375
    aqualectric
    No sump hose now……outlet hose looks as if it is directly off the pump. That’ll surely wear through blowing everything in sight….. :rolls:
    Post those pictures in the public forums!! :stir: :innocent:
    Steve.
    #278376
    Lawrence
    did someone say made in poland ?by Bosch or someone else I wonder …
    #278377
    helo_75
    so, theres no kick strip
    dead give away.. no kickstrip/pump filter
    when will it all end
    #278378
    BSH-MAN
    don wrote:
    Martin wrote:
    Thank’s for the tip about spotting the stub door handle. I’ll advise my customers to avoid those in future. 😉
    Made in Poland 😉
    Don
    Probabley Chinese but could be Polish. Sub £280? I saw that pump on training info 18 months ago but it was not fitted to U.K. appliances at the time. (This is first I’ve seen)
    You must understand that it is the Brand in this country that dictates to the factories what appliances/price they must supply.
    It may be an attempt to steal from some of the Indesit type market.
    My personal recommendation to anyone in the market for a cheaper end Bosch washer would be a WAE type.
    There is nothing unreliable about the WAA type, far from it. I just think for a little more money you get a better value with a Bosch WAE24363GB @ £317
    Iadom, do you have a model number? I cannot find any WAA’s on the Bosch web site any more. :con:
    #278379
    BSH-MAN wrote:Iadom, do you have a model number? I cannot find any WAA’s on the Bosch web site any more. :con:
    Jim gave it as the title of this thread. 😀
    #278380
    I did rip the label off the plastic bag with the manual etc in it but the last bit got torn off. 😥
    Definitely a WAA24270. My information was that this machine was an exclusive for indies only.
    iadom wrote:Definitely a WAA24270. My information was that this machine was an exclusive for indies only.
    And sold via…….
    http://www.pricerunner.co.uk/pl/14-1207 … are-Prices
    #278382
    BSH-MAN
    That may explain things a little. 😉
    #278383
    Turbo
    Went to a Bosch WAA28161 GB/07 this had a sealed drum and was manufactured in Oct 2007 to my surprise. Did not realize they had been out that long.
    Graham
    #278384
    boselecta
    Just bought in a load of WAA24171, they have a acessible filter and a splitable tub.
    Cant see the difference between this model and the supposedly better WAE machines to me.
