Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Bosch SGS43A42GB/01 – Very Noisy – Time to Change?
- This topic has 15 replies, 3 voices, and was last updated 14 years, 3 months ago by
SteCole77.
January 25, 2012 at 1:09 pm #67568
SteCole77
ParticipantHi All,
our trusty Bosch dishwasher is finaly on its knees. It is struggling on and still doing a good job.
The problems are that it needs a new lower door seal.. water leaks out if you open it when its running… pours out really and also it has developed an unbearable noise… very very loud.
It seems to be the main motor, as when emptying it goes back to normal. It’s only when doing the wash parts of the cycle that the noise is there.
Does main/run motor sound about right?
If so, it’s about £150ish for the seal and motor… from what i can see.
So i’m wondering if it’s worth it now after the best part of 10 years?
I’ve seen a fairly cheap Beko DWD4311W as possible replacement… Any advice on best thing to do?January 25, 2012 at 4:18 pm #367808Martin
ParticipantRe: Bosch SGS43A42GB/01 – Very Noisy – Time to Change?
SteCole77 wrote:If so, it’s about £150ish for the seal and motor… from what i can see.
If the motor shaft isn’t rusted badly then a new Impellor Seal Kit (174730) can be fitted for less than £50 if you’re up for it?
The door seal leaking could be that the machine is overfilling and time to remove, clean and refit the magnetic float that’s located just under the filter cover (grey plastic cover in 6 o’clock position)……simples!!
SteCole77 wrote:I’ve seen a fairly cheap Beko DWD4311W as possible replacement… Any advice on best thing to do?
Don’t buy Beko!………. instead I give you no less than 3 (three) possible alternatives….BOSCH, BOSCH and BOSCH…OK? 😀
January 25, 2012 at 6:21 pm #367809SteCole77
Ahhh cheers for that… i’ll avoid Beko lol.
I did fancy another Bosch as i know they’re good, especialy as this one lasted so long. Not cheap though lol.
I’m not afraid to take things apart so i’ll open it up and have a look!
The seal has never been changed and seems to be deformed now… plus i found a chunk in the drainage impellor!
It doesn’t usualy leak when running, just if you open it when full.Is it easy to get the motor out? Is the impellor attached to it?
January 26, 2012 at 8:59 am #367810Martin
SteCole77 wrote:Is it easy to get the motor out? Is the impellor attached to it?
Yes and yes.
January 26, 2012 at 12:45 pm #367811SteCole77
Thanks again,
I’ve got the motor off, nice and easy like you said… just have to remember where all the spade conectors go lol.
It’s pretty gunged up inside, between the metal motor case and the plastics of the impeller.
Looks like a slow leak, rather than more sudden problem.
The motor shaft seems to turn ok, smooth and quiet, so i’m not sure what would have been making the noise now. Unless it’s the seal arround the shaft.
Tempted to plug the motor back in and run it whilst the things in pieces.
Any thoughts as to what else it could be? Or does this all sound about right for needing the seal kit?
January 26, 2012 at 12:54 pm #367812Martin
Having got this far then fitting a new Impellor kit is your next move. You might also replace the ball race bearing directly behind the water seal as chances are that that it the noisy culprit. It’s a standard 608ZZ ballrace bearing and well worth fitting.
Please don’t plug it in until you reassemble it with the new parts I’ve advised you fit, there’s a good chap. 😯
January 26, 2012 at 1:23 pm #367813SteCole77
Martin wrote:Please don’t plug it in until you reassemble it with the new parts I’ve advised you fit, there’s a good chap. 😯
I fix photocopiers and big printing machines for a job, sometimes i have to remind myself that i don’t always know everything about fixing everything! 😀
I’ll get those bits ordered up, can’t find a shop to go pick them up.
Found one kit thats £38 but it doesn’t show the big ring seal that is shown in other arround the £47-49 mark.
That other bearing you sugested, is that the one at the base of the motor shaft? Does it just pry off?Cheers for this!
January 26, 2012 at 1:44 pm #367814Martin
SteCole77 wrote:That other bearing you sugested, is that the one at the base of the motor shaft? Does it just pry off?
Clearly you’re a fixer by trade so a little motor like this will present no problem. Once you dismantle the motor and armed with the correct impellor kit and new bearing, it’ll be all too obvious your next move….and yes the bearing just sits on the shaft so get out your bearing pulley, WD40 and 3 in 1 oil can……….easy peasey. 😉
January 26, 2012 at 2:38 pm #367815SteCole77
Hopefuly it will be easy!
Pressure is on when you’re paying the bills!
Also.. Showing me up now… Not got a bearing pulley! Not even sure what one is lol. I presume it’s some kind of extraction tool?
I’ll let you know how i get on, it’ll be a few days for parts… Unless you know a bood shopin the Manchester area?
Thanks again for the help!
January 26, 2012 at 3:16 pm #367816don
ModeratorRe: Bosch SGS43A42GB/01 – Very Noisy – Time to Change?
You should be able to get the parts through our own shop. Send an email to spares@ukwhitegoods.co.uk Don’t forget the all important enr and fd numbers 😉
Don
January 26, 2012 at 3:59 pm #367817SteCole77
Ok cheers Don, i’ll send them a message.
January 26, 2012 at 10:41 pm #367818SteCole77
Managed to take it apart, clean it up and put it back together correctly. So thats a start.
I think you were spot on Martin, about the noisey bearing. Might try and get one tomorrow, so i can use the washer over the weekend!
Thansk again!
February 8, 2012 at 3:38 pm #367819SteCole77
Been working away and so only just got the parts today.
I’ve fitted the new impellor and seal kit but couldn’t find/get to the bearing.
The motor is held together with 2 screws but one won’t come out and now the torx head is starting to round out…
So i’m guessing the bearings inside there some where?Any ideas?
February 9, 2012 at 9:10 am #367820Martin
SteCole77 wrote:So i’m guessing the bearings inside there some where?
Indeed the bearing is in the front metal housing, access via removal of the complete pump chamber. Then remove to 2 long Torx screws holding the motor ends and stator together. If the torx head is starting to “round out” it is usually a result of a bad fit between that head and the torx (T20) bit. Probably the bit needs replacing?
Failing that the only option is to saw the head of the screw and replace the screw on reassembly. (A good DIY/Ironmongers merchant should have a suitable replacement)Take great care not to damage the threaded rotor shaft when extracting it from the end frame. Damage that, even slightly, and it’s scrap metal at that point……. 😯
February 9, 2012 at 1:08 pm #367821SteCole77
Cheers, to be honest i was thinking similar to the screw head idea. Is it a nut in the hole on the other end, as i think thats where to problem is?
As for the torx bit, no it’s a new set.. well, bairly used anyway. It looks rusted in at the thread end. I think it’s rounded out as i’m straining away, holding the motor in one hand and driver in the other lol. Wobble.. Slip.. etc…I’ll get there in the end lol
