Re: Bosch SGS43C12 Dishwasher not finishing cycle
This m/c will not require the mushroom mod. As the fault was picked up long ago by the factories and the new style mushroom and pcb are now factory fitted.
However the water level should not get above the mushroom without bringing the pump in. If you turn m/c on then manually lift the mushroom does the drain pump run?.
BSH Appliance care 08705 678910
