Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Bosch SGS45C02GB problem
- This topic has 15 replies, 5 voices, and was last updated 12 years, 8 months ago by
rob yarrr.
August 9, 2013 at 7:36 pm #76606
rob yarrr
Participanthi, if anyone could help me i’d be very greatfull.
Problem is you put the washer on a quick wash, starts at 27 mins and seems on, gets to about 15 mins left and it just stops and the check water light comes on.
things i’ve tried: checked filters are fine, water getting in fine and the filter not blocked, all it won’t do is drain from what i can see, what would you suggest i do ?
also tried tipping it but all it does is fill with more water to the point it starts to run out of the door. thanks.
August 9, 2013 at 11:10 pm #398880Simon46
ParticipantAugust 10, 2013 at 12:43 pm #398881rob yarrr
ParticipantRe: Bosch SGS45C02GB problem
how do i get to the drain pump? i’ve done as the manual says and there’s nothing i can see wrong with the sump
August 10, 2013 at 2:28 pm #398882rob yarrr
tipped it on its front and removed all the pipes / drain pump and everything’s clear with no obstructions,pump impeller seems abit hesitant to turn, put it all back together and still no change, still won’t drain with the check water light coming on, what do ?
August 10, 2013 at 2:43 pm #398883stevebunyan
Have you checked the sink end of the drain pipe for blockages?
August 10, 2013 at 2:45 pm #398884rob yarrr
stevebunyan wrote:Have you checked the sink end of the drain pipe for blockages?
yeh is fine, i took it off the washer and swilled it through with boiling hot water, it empties out of the wall like normal from the sink, from what i can see the water isn’t even entering the drain pipe of the washer
August 10, 2013 at 3:18 pm #398885Martin
Take a look at the circuit board as I think there may be a dry joint?
August 10, 2013 at 3:50 pm #398886rob yarrr
Martin wrote:Take a look at the circuit board as I think there may be a dry joint?
how do i go about doing this ? thanks
August 10, 2013 at 10:13 pm #398887Martin
rob yarrr wrote:how do i go about doing this ? thanks
Why you simply remove the outer door panel and the fascia ’tis all….!
August 11, 2013 at 3:50 pm #398888rob yarrr
well took the facia off and the only way to the circuit board is to take it apart in a way i don’t think it’ll go back together
is there anything else that could be up with it ?
August 11, 2013 at 6:50 pm #398889rob yarrr
is there anyway to check the drain pump ? it gets to 16 mins, a relay clicks and then you hear something like the pump trying to turn but sounds like its catching and then stops and the check water light comes on
August 12, 2013 at 10:39 pm #398890stevebunyan
It does sound like glass or something jamming the pump. Time for it to come off me thinks.
August 13, 2013 at 11:36 am #398891rob yarrr
yeh its been off and nothing is in there which is odd, i assume this is the same pump that you can see in the left of the sump yes?
August 13, 2013 at 12:06 pm #398892Andy jones
Did you check the housing before put pump back on. Sound like a blockage if not sound like you need a new pump
Sent from my iPad using Tapatalk HDAugust 13, 2013 at 6:35 pm #398893rob yarrr
Andy jones wrote:Did you check the housing before put pump back on. Sound like a blockage if not sound like you need a new pump
Sent from my iPad using Tapatalk HDyup checked everything it can be, anyone know where i can get a pump from and for a good price? thanks
