Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Bosch SGS56E02GB/47 no heat and wont finish cycle
- This topic has 28 replies, 6 voices, and was last updated 19 years, 6 months ago by
MrO.
July 19, 2014 at 10:09 am #190803
frustin
ParticipantRe: Bosch SGS56E02GB/47 no heat and wont finish cycle
I spoke to soon, its not fixed. 🙁
There is heat i.e. the water gets hot but the cycle is getting stuck on rinse. if i press the power off and then on again the timer will show 39 minutes again. sometimes when i do this it continues through to the end of the cycle and dry the the contents.
July 19, 2014 at 10:45 am #190804Martin
I would check the PCB for burnt relay pins if I were you. 😉
July 19, 2014 at 12:03 pm #190805frustin
assuming that is easy to get to…is the part expensive?
July 19, 2014 at 12:14 pm #190806Martin
frustin wrote:assuming that is easy to get to…is the part expensive?
Fairly easy to access and if you can’t repair it with a dab or two of solder (assuming all the while it shows signs of dry/burnt joints). Then you can go on the Bosch spares website (Bosch’s own site not eSpares or other robbing merchants) and find the price yourself. 😀
July 20, 2014 at 9:32 am #190807frustin
PCB on the right hand?
July 20, 2014 at 9:50 am #190808frustin
These relays dont look burnt. The capacitors haven’t blown either.
July 20, 2014 at 10:21 am #190809Martin
Yep! All looks OK, visually at least. 😉
July 20, 2014 at 6:30 pm #190810frustin
what else could i be looking at? Wash cycle not finishing. Rinsing for ever, then it gives up, says it’s finished (zeros on the display) and the stuff is still wet inside.
July 20, 2014 at 6:56 pm #190811Martin
frustin wrote:what else could i be looking at? Wash cycle not finishing. Rinsing for ever, then it gives up, says it’s finished (zeros on the display) and the stuff is still wet inside.
I think we’re going round in circles on this one. But without even seeing it I know it is not heating…correct?
Apparently you recently got it going and it completed a cycle successfully. So, either the PCB is not providing power to the heater, or the heater is faulty or the water flow rate insufficient to operate the heat safety switch on the end of the heater box…???
July 21, 2014 at 8:39 am #190812frustin
ready for the tip i think. As you can see from the date this thread started 2007 we’ve had it for quite a long time (about 9 years).
Cost of repair plus the hassle doesnt sound like its worth getting fixed.
July 24, 2014 at 2:15 pm #190813frustin
no, not quite ready for the tip yet.
Since putting the front back on, it’s started to work again. 3 loads down the road and we’re still good.
crossing my fingers for another 7 years.
November 13, 2014 at 10:44 am #190814frustin
Something popped this morning and a burnt electrical smell. It finished the cycle though. Capacitor? do i need to be concerned as it’s still finishing the cycle.
November 13, 2014 at 4:59 pm #190815Martin
Mains filter blown
November 13, 2014 at 7:23 pm #190816lee8
It’s begging to be replaced.
