Bosch SRS43C22GB/04 – Check Water light
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch SRS43C22GB/04 – Check Water light
Viewing 12 posts - 16 through 27 (of 27 total)
  • #366116
    Re: Bosch SRS43C22GB/04 – Check Water light
    dave-m wrote:Anyway, my question is, can a m/c just start siphoning for no apparent reason after 5 years of working normally?
    Yes, if the non-return valve (165262) in the pump outlet chamber has been removed or perished. ๐Ÿ˜‰
    #366117
    dave-m
    I’ll check it out and let you know.
    cheers
    #366118
    Would be unlikely to do so on a consistent basis, I would think unless someone moved the position of the hose inadvertently at some point before they called you in.
    Mike.
    Oops, hadn’t seen Martin’s reply.
    #366119
    OLLIE2806
    Today i changed the board but still exactly the same, Im stumped!
    #366120
    Have you read through all “related topics” at foot of thread?
    Mike.
    #366121
    OLLIE2806
    Hi mike,
    Yes i have had good read but im pretty sure ive tried everything ive read – Impeller jug, valve, pcb, transfer pipe & pump is clear, I havent changed the metering tank but that looks clear
    #366122
    Allsorts
    This might sound stupid.. but are you sure the water supply valve is working … that there is actually water getting to the inlet valve.
    #366123
    From one of those threads,
    Postby nomadPaul ยป Mon Mar 29, 2010 5:08 pm
    Remember that the check water light may come on if there is a drain problem
    Re: Bosch d/w sgs55c02gb/01 check water light
    Postby grazzamongrel ยป Mon Apr 05, 2010 7:34 am
    Just to let you all know put new float chamber on and problem solved and cleaned hose from there to sump as a precaution as it was slightly gunked up. Many thanks for all your replies though they were greatly appreciated
    Couple of things there to be thinking about. Seems to me that if the machine either is not or “thinks” it is not fully drained, then it will not start to fill. The red float thingummyjig in the fill matrix, or its attendant microswitch or something around that area could be sticking even if it looks all clean.
    Mike.
    #366124
    dave-m
    My customers m/c is now in my workshop and has worked fine on numerous washes.
    I have the hose lying on the floor and the m/c raised to try and simulate his installation and get it siphoning but it still works fine (I suppose I should be happy about this!!)
    As I replaced the impeller jug on first visit with no joy I can only assume that there was a blockage on the the float chamber or the fill matrix or something that shifted on transporting it to mine (although look clean), either that or it’s a water pressure problem or external drain problem at his house.
    Either way, I’ve found nothing solid to blame the fix on.
    I just hope it works when I bring it back……
    OLLIE2806
    Ive Checked the microswitch etc – All fine. Ive identified the cicking to the diverter valve on the heater, Also ive found something a bit strange – the bit of wiring loom that connects the divertor the circ pump and the mircroswitch appears to be down to earth, when i do an insulation Res Test from the small tag for the circ pump to earth it reads 0.08 (even with Circ Pump, Divertor and mircoswitch disconnected but when i disconnect the connector from that part of the pcb the reading comes right up fine. Any ideas?
    Im going to give up on this one soon. LOL!
    #366126
    OLLIE2806 wrote:Ive identified the cicking to the diverter valve on the heater,
    You’ve done what? ๐Ÿ˜•
    #366127
    He means clicking as mentioned in his opening post.
    Mike.
