BOSCH WAE 24164
Viewing 6 posts - 16 through 21 (of 21 total)
  • #371294
    colly
    Re: BOSCH WAE 24164
    Not very often so this is why i think the board has been damaged
    colly
    #371295
    Re: BOSCH WAE 24164
    Same here, I can only remember about three occasions in my experience.
    I was asking Nomad paul though.
    Guess you’re not seeing the avatars tonight either 😉 .
    Mike.
    #371296
    colly
    Re: BOSCH WAE 24164
    Thats right man !
    Just reading the post re f21 fault disconnect motor then do a reset
    Tried a normal reset on first visit ie turn dial to six seven etc ,hoping it would just be that after i had changed valve,but no seems to work .
    I may try again disconnect valve reset pcb the re connect valve .
    colly
    #371297
    keithwilliams
    Re: BOSCH WAE 24164
    hi colin
    i’ll have a dig about cos i might have a board that’ll fit your machine. i’ll give you a ring thursday.
    keith
    p.s do you know alans on here now. alanmstorey
    #371298
    Re: BOSCH WAE 24164
    colly
    Sounds like clutching at straws, to me 😉
    Bet you the valve triac’s not conducting. I don’t know that board but if you can find out which triac is involved by following the wiring, you might be lucky and find that’s all that needs doing on the board. Rest of board function is obviously unaffected.
    Mike.
    #371299
    colly
    Re: BOSCH WAE 24164
    Hi Keith
    That would be great if you have !!
    Cheers
