Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Bosch WAE2416SUK smells of urine
- This topic has 24 replies, 5 voices, and was last updated 14 years, 5 months ago by
Helen Jones.
October 30, 2011 at 12:23 pm #65953
Helen Jones
ParticipantMachine is just under 2 yrs old and over the last couple of months it gives a terrible smell when in use, can only describe it as strong urine. Have done all the usual, cleaned everything, boil service wash and it still smells, no smell anywhere when not in use, drums and seals are as clean as a whistle, now run out of ideas and worried if i contact bosch and they come out and say nothing is wrong they will charge me.
Many thanks for reading
October 30, 2011 at 1:22 pm #362487kwatt
KeymasterRe: Bosch WAE2416SUK smells of urine
Hi Helen,
It’s what you can’t see that will smell and it won’t be a fault on the machine that Bosch can sort.
This may help though: http://www.ukwhitegoods.co.uk/help/fix- … hines.html
October 30, 2011 at 2:31 pm #362488Helen Jones
ParticipantRe: Bosch WAE2416SUK smells of urine
Thank you kwatt. I do use ariel gel and will now purchase the powder and do a couple of boil washes with that and see if that helps, will also see if i can find some affresh, i have never heard of it or seen it so hold little hope of finding it but will certainly look, i have used gel for years with previous machine and never smelt anything like this and my last machine was years old. Thank you for the advice and link
October 30, 2011 at 3:07 pm #362489October 30, 2011 at 4:47 pm #362490Martin
Burnt heater terminals or poor wall socket contact can give off a similar ‘whiff’…. 😉
October 30, 2011 at 7:25 pm #362491Helen Jones
Martin wrote:Burnt heater terminals or poor wall socket contact can give off a similar ‘whiff’…. 😉
How would i check this?
October 30, 2011 at 9:59 pm #362492iadom
ModeratorRe: Bosch WAE2416SUK smells of urine
Check the mains plug and the socket visibly, look for any signs of burning, smell the plug. If it is fine then the heater terminals are inside the machine, it is just about possible to see them from underneath with the machine leant back against a wall or cupboard.
The smell from such things is very distinctive, totally different to a detergent/low temp problem, in fact very much as you describe.
October 31, 2011 at 12:38 am #362493Helen Jones
thank you iodom will pull machine out tomorrow you have any links to show what i am looking for inside the machine or will it be obvious
October 31, 2011 at 9:29 am #362494SaabbaFan
We had the same problem with our ISE havign never had the problem before with any machine. We were using eco friendly liquids and no hot was or machine cleaner stopped it. Clothes smelled of it as well, and needed hours on the line to freshen up.
Switched back to powder and it’s been fine ever since. I think we did put a couple of hot washes with bio liquid through, that has enzymes in it which I think are supposed to eat away the smelly stuff.
Now on asda eco powder or Surcare and no problems.
October 31, 2011 at 10:45 am #362495iadom
If it is the plug it will be obvious, the heater less so but you can just about see the heater terminals at the bottom of the front of the drum if you look up inside the front of the machine.
October 31, 2011 at 11:40 am #362496Helen Jones
thanks saabbafan, b ut this is why i did not think it was from build up as the washing does not smell at all, infact even immediately after opening door there is no smell whatsoever, only smell it whilst on and never after
iadom, will they look burnt out or something, will it be obvious there is something wrong, don’t want to be pulling it out till i definately know what i am looking for and how it should look, as i have never seen it before i need to know what it should be like, i am referring to the heating terminals not the plug or socket lol
October 31, 2011 at 4:47 pm #362497iadom
Its usually fairly obvious, in most cases the heater terminals have plastic sheaths on the with will be discoloured.
October 31, 2011 at 10:12 pm #362498Helen Jones
iadom is it the wires that clip onto the heating element?
like in this video http://www.youtube.com/watch?v=PMYM_j8Uoyk
I am having a problem distinguishing what a heater terminal is 😳
October 31, 2011 at 10:31 pm #362499iadom
At about 2.45 to 2.50 into that video you can clearly see the heater terminals, they are sheathed in black and dark pink plastic covers.
It is possible to view these from beneath without removing the front panel.
November 1, 2011 at 10:04 am #362500Helen Jones
Well everything looks good under machine, but this not looking so good
