Bosch WFL2260 motor access
Viewing 15 posts - 1 through 15 (of 30 total)
  • #12280
    I thought the WMA motor was a little awkward to get at but this Bosch is about the worst I have seen yet. I have managed to remove the brushes by lying the machine carefully on its back and with a bit of fiddling remove the worn brushes. Is this the ‘recommended’ way, and how do you get the motor off if you need to change it, surely you don’t have to remove the drum assy?
    Spares question, is the Qualtex CAR 93 the same as the Bosch 154740 carbon brush ?
    #148839
    Goatboy
    Re: Bosch WFL2260 motor access
    Errr… Is that plastic tub or cast-iron spider?
    #148840
    Goatboy
    Ahhh, plastic tub!
    It aint so bad. We just tip the machine back a little for access, but don’t tip it all the way onto it’s back.
    There a whole thread on Bosch brushes somewhere.
    #148841
    Goatboy
    Found it!
    #148842
    No! No! tipping the machine on it’s back is not the way to do it. :lesson:
    Tip it on it’s front, back panel off, undo the 2# 10mm bolts with a small 10mm 1/4inch drive socket and ratchet spanner. Drop the motor out and BINGO, easy access 😆
    Easy job, 15 minutes on average to include multitasking lecture to your customer whilst doing the repair on soap powder technology. They will love you for it! 😀
    #148843
    Goatboy
    Martin wrote:No! No! tipping the machine on it’s back is not the way to do it. :lesson:
    I meant access is from underneath. I tip the machine slightly forward or backwards, depending on the kitchen, length of pipes etc.
    Of course, I’m only little so I can crawl under the washer pretty easy. 😉
    #148844
    I should have said tilted right back, not laid flat. Still think motor bolt access it is an awful piece of design, if only someone would make a machine once again, on which the full back comes off. 😉 Its streching it a bit to call the pathectic little piece of metal on this Bosch a back panel, but once again no doubt the accountants are interfering. 😥
    #148845
    iadom wrote: on which the full back comes off. 😉
    There is plenty of access though on this model even with the back off. (You will find – in due course- that the UKWasher has a similiarly small back panel, but yet offers enough access to do the job 😉
    #148846
    Are we talking about the same machine, this so called back panel is not much bigger than the pulley access panel on a Hotpoint WM machine, and the cabinet back has some very sharp edges.
    #148847
    Yes indeed! Enough to access the 2~ 10 mm hex screws and the pulleys as previously mentioned (mind though, the edges are unforgiving!)
    Drop the motor out, saves all the contortions required otherwise 8)
    #148848
    bobokines
    It’s the 10mm ratchet spanner that makes all the difference.
    Bob
    #148849
    superfix
    Easy peasy one handed job.
    tilt forward to about 45 degrees, use knee or any other part of the body to support.
    remove bolts, prise away from mounts with flat blade screwy, catch motor with other hand. Bish bosh 10 mins later one changed motor.
    Wait til you see the new wfd motor!!!! :tdown:
    #148850
    Another way to get at those motor bolts is to drill two holes, in line with them, just big enough to get a quarter inch drive extension bar through.Fit your 10mm socket to the bar after passing it through the hole.
    Use the customer’s own electric drill to save yourself the inconvenience of bringing your own.(The customer’s probably got a much better one than yours anyway and it’s hardly had any use ’cause he always calls in people like us to do the job).(If the hubby’s not there,get the woman to call him at work to find out where the drill is). You have to teach these people to buy machines with good access otherwise things’ll just get worse. 🙂
    Incidentally,overgrazing is a serious problem and you shouldn’t joke about it. 😆
    #148851
    Did the job today, a doddle with a ratchet. 🙂
    #148852
    You’re all bonkers. Tilt the machine sideways – 10mm ratchet drops in sweet as you like, plenty of room to work, off down the road in no time.
    LMTGOWI – I hope you’re fitting blanking grommets into the gratuitous holes.
    Cheers,
