Bosch WFO 2866/gb
Viewing 15 posts - 1 through 15 (of 18 total)
  • #28825
    steved20
    Hi there, My machine works fine but does not heat up the water,
    I have replaced the water level sensor, heating element & the thermostat any advice what it could be, thanks in advance, steven.
    #220225
    clivejameson
    Re: Bosch WFO 2866/gb
    What are the exact symptoms?
    You set it off to wash and then tell us the sequence of events?
    #220226
    steved20
    I have tried various heat settings 30, 60 & 90 degree settings, checked all the cables but the machine doe not get hot.
    #220227
    gegsy
    Considering you have changed almost everything connected with the heating circuit, there can really only be a break in the wiring loom somewhere or the module is in fact defective IMHO 😕
    Also can you tell us is it a GB/01/05 or 07 😉
    clivejameson
    does it throw up an error code (lights flashing)?
    #220229
    steved20
    All appears fine, it does have a little digital display which shows remaining minutes but no flashing or error codes.
    #220230
    helo_75
    does it go through its program? are u SURE its not heating?
    #220231
    steved20
    We have spent hours trying different programs, the drum stays stone cold, its driving us nuts as we have spent a few quid on new parts up to now.
    #220232
    steved20
    Sorry I missed the earlier post it is a GB/01
    #220233
    steved20
    I tested all the wires from the module to the water level sensor, to the heater, the thermostat and back to the module with a circuit tester and there are no breaks Im baffled.
    #220234
    gegsy
    It may be worth you removing the module and looking for any poor solder joint/s around the relay pin/s, esp one feeding the heater.
    Power off of course :plug:
    steved20
    When we took it out a while ago it had a black sooty residue around it. At first we thought it had burnt out but it just wiped off
    #220236
    steved20
    Where is the relay Pin situated, regards Steven.
    #220237
    gegsy
    Just look at the pcb carefully and see if you can spot any bad joints, they are usually pretty blatant 😉
    We are getting close to pointing you towards repair@ as the fault doesnt appear to be a straightforward fix on here, sorry.
    steved20
    If the board is faulty, where would be the best place to buy one if it got to that stage, regards Steven
