Bosch WTA4408 – Not heating
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch WTA4408 – Not heating
Viewing 15 posts - 1 through 15 (of 22 total)
  • #16296
    Birds
    The above dryer has had the same fault before (well symptom) and the Bosch service engineer merely pressed a reset switch. All has been ok for 7 months untilk now.
    Please could someone advise on where this reset switch is located so I can try this before I call out an engineer.
    #169171
    Re: Bosch WTA4408 – Not heating
    There will be more to it than pressing the reset under the rear panel. The machine is basically an air pump – if the flow becomes restricted an overheat will result. Check vent hose is not kinked/trapped/fluffed-up, the through-the-wall ducting likewise. You should feel a good draught of air at the outlet duct.
    Power off before removing any panel,
    Birds
    Ok thanks for the response. The air flow is good (just very cold). I checked the hose and all looks ok. It is only about two metres long and vents out of a fanlight window.
    So the reset switch is behind the rear panel, yes?
    Thanks again.
    #169173
    gegsy
    Hi Birds
    Are you being naughty and stopping the drying cycle mid heat, removing clothes and leaving dryer without a 10 min cool down? Thats the most popular along with overloading.
    Birds
    Greg,
    This may have been the case initially – I do not know. My wife is the user.
    If this can cause the fault to start with then we will take heed.
    However now the heater is not working at all. It’s been out of order for a few days. The same as the original problem months ago.
    #169175
    gegsy
    Remove rear panel, power screwdriver will be helpfull, reset thermal trip and re assemble. If still no heat you will need engineer, see link below.
    Greg 😉
    #169176
    Birds wrote:vents out of a fanlight window.
    As in hose thrown out of window? If there is no cowl on the end, the wind coming round the wrong way can effectively block the hose by blowing into the vent hose, thus tripping the safety stat under the rear cover…….
    Power off………
    Birds
    Greg and Penguin45,
    thanks for your help and promt responses. I will attempt the reset and take the tips on board.
    Regards
    #169178
    gegsy
    You welcome, anytime.
    Greg 😉
    #169179
    Birds
    Greg,
    found the reset button, however using an ohm meter the element (disconnected) does not give a reading – so I assume this has gone.
    I find this pretty poor for a 18mth old Bosch.
    Regards
    #169180
    Goatboy
    Did you press the button on the reset stat?
    #169181
    Birds
    yes done that and there is conductivity through the switch when checked with a meter.
    #169182
    Goatboy
    Birds wrote:…using an ohm meter the element (disconnected) does not give a reading – so I assume this has gone.
    Ahh…Sorry, I read this too quick and thought that you meant the reset stat 🙄
    I could tell you price for the element, but I need to check that you are sat down first 🙁
    #169183
    rungidung
    Birds wrote:Greg,
    Regards
    I would have thought that the dryer would still be under warranty from Bosch as they are guaranteed as far as I am aware for 2 years, assuming that you have still got the invoice.
    cheers
    #169184
    gegsy
    cheers
    You are correct Clive (Hows your dryer after Dansta sorted it?)
    If you have a current receipt for the appliance and is within the 2 years of purchase contact your nearest BSH engineer.
    Im assuming your model is WTA4408GB/01 th n heater will be 492159 -£59.00 + VAT BSH pricing; if it is out of warranty.
    FYI Ive changed a few under warranty .
