Re: Bosch WVT1260 steaming
martfoxy wrote:Do the inlet valves get scaled up and reduce the water flow?
Yes they can do but in the case of the dryer/condenser valve it is only a small trickle of water that passes through constantly. As a rule if you have any flow at all then that proves that the inlet valve is OK.
…..and yes they do run warm, the coil does anyway.
