Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Bosch WVT1260GB Drum Not Rotating
- This topic has 18 replies, 5 voices, and was last updated 13 years ago by
yucca.
April 15, 2013 at 7:38 pm #393310
yucca
ParticipantRe: Bosch WVT1260GB Drum Not Rotating
Thanks for the tip.
I’m happy to spend the cash If the motor is faulty. Like everybody else out there, I don’t want to throw good money after bad since a new machine is so much cheaper than the sum of its parts.
So, is there any other final test I can make to confirm that it is the motor and not anything else?
I’ve managed to take the motor off this time, so I could set the machine going and check the voltages at the 6 pins on the plug which connects to the motor. The trouble is I don’t know what to expect.
I know two pins will be for the brushes. And some pins will be for the field windings to generate the magnetic field … But what about the speed controller?
Does anyone know which is which? And what voltages I should be getting at each pin? I guess direction is controlled by another component higher up in the chain because I recall hearing clicks (relays?) whenever the direction of rotation changed.
Any insight would be gratefully appreciated!
April 15, 2013 at 8:29 pm #393311iadom
ModeratorRe: Bosch WVT1260GB Drum Not Rotating
The test you have already done confirms the motor is faulty, if you have an OC condition between two of the contacts then the motor is faulty, 99{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} certain the overload has blown. If the overload had blown then that means the rotor/comm is in poor condition.
Sent from my iPad using Tapatalk HDApril 16, 2013 at 8:41 pm #393312yucca
Ok, thanks.
In addition, my father-in-law has come across another machine of the same type and has taken resistance readings for the pins:
*) Pins 1&2: His:1.3 ohm, Mine:1.2 ohm
*) Pins 3&4: His:3.1 ohm, Mine:infinite
*) Pins 5&6: His:15 ohm, Mine:15.5 ohmSo that that’s conclusive. I was going to measure the voltage at the connector with the machine switched on during a spin cycle however my multimeter’s prongs were too large to fit into the slots and I didn’t want to damage the plastic plug by forcing them in.
One final thing, I tipped the machine on it’s left-hand-side to access the motor. I may be mistaken, but to me now, the drum seems to sit slightly higher than before.
It could be that normally there are clothes in the machine weighing it down. Does it sound like I’ve cream-crackered the suspension system (two springs on top and 2 support struts at the bottom)? Or am I just imagining this?Thanks
April 16, 2013 at 8:55 pm #393313iadom
Tipping it over carefully shouldn’t cause a problem, as long as the drum looks central it should be ok.
