Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › C2218 oven problem
- This topic has 16 replies, 3 voices, and was last updated 4 years, 4 months ago by
spacebischit.
December 5, 2021 at 9:38 pm #100318
spacebischit
ParticipantHi,
I have a Caple C2218 single fan oven. The LCD displays the time which I have set but the oven functions will not heat the oven, the fans do not work, the oven light does not work and the light indicator on front of oven does not illuminate.
I know it is probably not worth repairing but it is bugging the hell out of me since I now have the back off and Ive been figuring bits and pieces out.
I have tried with a multimeter taking readings of the back of the function selector switch, but always 0v as I click through the selections. I also tested the back of the thermostat on the back of the heat selector dial with 40v off, then as it clicks to call for heat 0v.
Not sure if any of this helps? Any ideas. This is more a project that anything else and would be useful to simply identify the cause of fault even if I don’t fix it.
Thanks.
December 6, 2021 at 1:19 am #480161kwatt
KeymasterAre you sure it’s not on auto?
If the timer is on an auto function you’d get what you describe.
December 6, 2021 at 8:47 am #480162spacebischit
ParticipantHmmm, there is an icon that looks like ‘heat’ which is illuminated as soon as the oven has power. I don’t seem to be able to turn that off. I did already try cycling through the auto and semi auto modes and the word Auto shows in the display when I do so.
December 6, 2021 at 9:56 am #480163electrofix
Moderatorspacebischit wrote:Hi,
Thanks.
from what you say your missing a live
check the clock first. there is a relay in the clock that controls the power to the oven. when you set to manual it should close and alow power to get to the selector sw. if this is the fault you can link it out to save buying a clock
after that its a selector sw problem most likely
December 10, 2021 at 12:03 am #480164spacebischit
ParticipantThis is the back of the clock:
The relay is the white plastic box if I am not mistaken? Any tips on how to test this, I am thinking I might disconnect the right most blue wire (which has 2 wires) and check for a voltage there?
Thanks in advance.
December 10, 2021 at 12:05 am #480165electrofix
Moderatorfastest way link the 2 blue wires together and if it runs its the clock
December 10, 2021 at 8:56 am #480166spacebischit
ParticipantOk so unplug the two blue wires on the left and making those to by-pass the relay?
December 10, 2021 at 10:13 am #480167electrofix
Moderatorcorrect
December 11, 2021 at 1:17 pm #480168spacebischit
ParticipantBy passing the the relay and the oven functions work! Does this suggest the relay itself is the problem or could it be something else on the circuit board?
Seems to be a cheap part to replace – although will require removal of the board and re-soldering which I can handle.
Thanks for the help!
December 11, 2021 at 7:05 pm #480169electrofix
Moderatorrelay could be the problem or the clock is not energising it
or if you dont use the clock remove the clock board and solder some heavy wire across the bock of the terminals
clock will then show time but you cant use auto on the oven
December 15, 2021 at 2:33 pm #480170spacebischit
ParticipantI’ve ordered a replacement relay, I’ll report my finding once I have fitted and tested it.
On another note, there is what looks like fan to extract heat on the exterior of the oven at the back (not the internal circulating fan). How is this triggered? I suspected the thermal cut out – I tried disconnecting the two wires which I guess is what happens when the normally closed (?) thermal switch hits the rated 220c to make it open?
Thanks.
December 15, 2021 at 5:05 pm #480171electrofix
Moderatorit will either be controlled by a pcb or a normally open thermal sw
December 17, 2021 at 9:22 am #480172spacebischit
ParticipantI figured the fan out, there is a thermostat (normally open) which fires the fan when the temperature hits it’s threshold.
I have changed the relay but it didn’t fix the main issue, I’ve check the capacitors and resistors they “look” ok and seem to give expected readings with my multi-meter.
There isn’t that much to the PCB:
I’ve removed these two safety capacitors which do not give any readings, I believe they protect the circuit.
The PO mentioned something about a power surge which caused the issue, so perhaps this is the fault. They are cheap as chips so have ordered replacements.
December 17, 2021 at 10:08 am #480173electrofix
Moderatorthe grey one will provide power to the circuit so might well be faulty
changed load of those
December 17, 2021 at 1:59 pm #480174spacebischit
ParticipantGreat – seems as if I might be onto something here at last then!
