Home › Forums › General Trade Forum › Calling UKW Refrigeration Engineers
- This topic has 29 replies, 16 voices, and was last updated 20 years, 5 months ago by
November 5, 2005 at 9:29 pm #151818
ParticipantRe: Calling UKW Refrigeration Engineers
Did anyone do it then?
November 5, 2005 at 10:50 pm #151819eastlmark
ModeratorRe: Calling UKW Refrigeration Engineers
Yes Chris, emailed 2 minutes ago! your timing is impeccable! 😡
November 5, 2005 at 11:40 pm #151820Dave_Conway
Just got it thanks Mark :tup:
I’ll publish tommorow.
Thanks again..
November 5, 2005 at 11:48 pm #151821Penguin45
Nice one…….. 😀
November 6, 2005 at 12:55 am #151822Pat-UK
off topic but I can’t believe you lot are still awake.
I thought I was the only midnight stress bunny around
November 6, 2005 at 1:47 am #151823Penguin45
Finishing my last pint about now…….. No stress, drown it with beer. 😀
November 6, 2005 at 3:10 pm #151824Dave_Conway
Yer tiz:
http://www.ukwhitegoods.co.uk/modules.p … ge&pid=108
Ken may want to add some piccies of course 😀
I’ve added to Kevin’s “sticky” in the fridge forum, if anyone thinks it requires more publicity, please let me know .
Thanks again Mark
November 6, 2005 at 4:29 pm #151825Penguin45
That’s excellent, Mark.
November 7, 2005 at 7:04 am #151826bobokines
Dave, Is there any chance of a bit on about adequate cabinet ventilation. I see loads of Mistrals with blocked condensers where the dog sits in front and blocks it up with dog hair. The sympton is the freezer runs, cycling on the compressor overtemp stat and usually runs at -12 to -15 degrees (warm enough to bring on the overtemp light but not obvious where the fault is)
I don’t do refrigeration appliances now but I do know this is a very common fault that can easily be rectified by the customer without an engineer visit.
I think the sticky is brilliant. :tup: Just the right length without too much high tech talk.
Small typo. Second to last paragraph, second to last line. “cause” spelt “caus”
Bob
November 7, 2005 at 7:46 am #151827roly16
Small typo bobokines; second line, ‘sympton’ should be ‘symptom’ 😆
November 7, 2005 at 7:54 am #151828bobokines
It is early 😉
Bob
November 7, 2005 at 7:59 am #151829roly16
Excellent article, Mark, thank you. Can I just query one point? You say that thermistors can’t be tested, but if you measure their resistance while warming them up [or cooling them down] and it changes, that’s a fair indication that they’re working. Obviously you don’t know if the resistance range is right without the relevant info., but if there are 2 identical ones on the machine that tells you. I don’t think I’ve ever found one where the resistance still varies with temp. but the range has changed. Does it happen?
Thanks again for the article.
GeoffNovember 7, 2005 at 9:36 am #151830Dave_Conway
Typo corrected and a small paragraph added about ventilation 😀
November 7, 2005 at 5:57 pm #151831eastlmark
roly16 wrote:Excellent article, Mark, thank you. Can I just query one point? You say that thermistors can’t be tested, but if you measure their resistance while warming them up [or cooling them down] and it changes, that’s a fair indication that they’re working. Obviously you don’t know if the resistance range is right without the relevant info., but if there are 2 identical ones on the machine that tells you. I don’t think I’ve ever found one where the resistance still varies with temp. but the range has changed. Does it happen?
GeoffYes Geoff, we do know that but, the article is intended for the public and I didnt want to get too technicle on that sort of stuff otherwise we will get asked about the correct resistance readings and stuff which, TBH we dont know. Not sure any of the hotpoint ones are identicle as they have different part numbers and plug colours. Not sure about the your last point, but I have had, on laundry anyway, thermistors that check out ok on a meter but fail in use, maybe temperature related failures?
As for Bob’s dog hairs, it was a frost free article rather than general refrigeration, maybe someone else may want to write that one?
Ad
November 12, 2005 at 9:08 pm #151832johno1998
bryan, thank you please :?:i need to know nothing 😕
