candy cic60 wire came off of timer unit?
Home Forums Public Support Forums Help And Support Washing Machine Help Forum candy cic60 wire came off of timer unit?
Viewing 15 posts - 1 through 15 (of 17 total)
  • #8426
    I have just received and replaced the motor on my cic60. problem is a few of the timer wires have come off and i don’t have a diagram. has anyone got a detailed description of where the wires go back on?
    The wires are:
    thick red
    brown and white together
    thin red with plastic plug on
    Ian
    #128593
    Re: candy cic60 wire came off of timer unit?
    Ian,
    Can you supply us with the 8 digit ‘type’ number of your machine? I think it should start with the number 3???????. Usually on a label on the back near the lid. Better still, give us all the numbers 💡
    Hi martin,
    Thanks for your prompt reply.
    The number you require is: N. 37616489 0323 2780
    The wires that have come off are:
    A thin red wire with plastic end
    A thick red wire
    2 wires joined together (brown and white)
    Any help appreciated
    Ian
    #128595
    londonboyz wrote:The wires that have come off are:
    A thick red wire
    One red (that comes from the Thermostat) goes to Terminal 4B
    The other red (that comes from the Motor) goes to Terminal 2B
    The brown/white goes to Terminal A
    Check carefully those red wires now! 😉
    Sorry to be a pain but when you refer to terminal references i only have B B T T L L
    also there is r2 c4 and c6 at the bottom of the timer
    any ideas ?
    Ian
    #128597
    has anyone got a picture or a diagram for this machine they can send by email. i only need something with the timer plug wiring.
    thanks
    ian
    #128598
    sorry forgot tosay my email is marjur6@aol.com
    thanks again
    ian
    #128599
    Sorry Ian but I have no wiring diagram for that type of timer or can find any reference to it being modified either, sorry 🙁
    so where did the advice about the wires come from ?
    was it just a guess ?
    #128601
    I am hoping to have a wiring diagram for this make on monday 😆 ,so if i can be of assistance please leave a message here. i will NOT answer private emails to me.
    Ian
    #128602
    londonboyz wrote:so where did the advice about the wires come from ?was it just a guess ?
    Guess??? No we’re not in any guessing game here, but I quoted you the wiring connections for the model number you gave me. It transpires however that the Timer unit has since been replaced (apparently)on later models (such as in your case) Sadly, Candy have not advised us/me of the new wiring modifications for it. 😥
    hI,
    sORRY I MEANT AN EDUCATED GUESS NOT A GUESS AS YOU MEAN IT.
    aNYWAY THE LATEST IS I HAVE NOW GOT A WIRING DIAGRAM THAT SHOWS THE OLD TIMER AND THE NEW UPGRADE, PROBLEM IS WHEN I CONNECT THE WIRES AS IT SAYS IT NO LONGER REVERSES
    Hi Martin,
    My apologies, i did not mean it as i wrote it i was meaning more towards an educated guess rather than anything.
    Anyway i have now got a wiring diagram showing the old timer unit and the new timer unit. i have the newer one. My problem is when i put the wires on as it states to do, the machine no longer reverse tumbles. It goes one way only but is working 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}. if i take one of the red wires off and put the other wire on it tumbles the other way !!!. I have tried a bit of trial and error in trying the other wire on different points but then the machine either don’t tumble or the fuse goes !!!!
    Any ideas?
    Ian
    #128604
    Assuming that you have wired the timer exactly as per the new timer chart, the fault must lie at the other end of the wire – the newly replaced motor may be wired incorrectly?
    Safety First,
    londonboyz
    The wiring on the motor was not touched in any way as it was simply 2 plugs. The motor came pre- wired with a socket on which i simply plugged into. This really has me at my wits endi’d rather dismantle a cr01 dyson and reassemble it than this. candy (gias) won’t help any further other than selling me a ‘wiring diagram’ that appears to have a few ‘needed’ pages missing. When i rang them today they said ‘what you have is what out techs go by’ !!!. lets hope this is the start of a hot summer 😆 .Then i could throw this cic60 away !!!
    ian
    #128606
    Ian,
    I was a Candy agent for many, many years and on occasion they still call me looking for me to bail them out the crap. If you got a schematic that was legible and not in Italian then consider yourself as doing well.
    And they’re not the worst, the Chinese are better at non-information in pigeon English or, Chinglish as it’s commonly referred to.
    Oh and Dyson just don’t do service information, period.
    Welcome to our world.
