CDA CW494
  • #21308
    PerranOak
    I have a built-in CDA CW494 that sometimes, just after the final rinse and just before the pump finally empties it, starts beeping and will continue all day if left!
    If I open the door when the beeping starts, the machine seems to have finished but is VERY steamy and hot.
    Resetting doesn’t seem to work. I have no manual and can’t find help, anywhere.
    Any tips would be gratefully received.
    Cheers.
    #190391
    Re: CDA CW494
    when you open the door, count the flashes between the pauses and that will give you a fault code, let me know how many times it flashes and ill tell you 🙂
    It could possibly be an NTC fault or a control board fault on the heater circuit.
    #190392
    linrew
    Re: CDA CW494
    hi
    these machines usually come with a 5 year warranty, it may be worth contacting CDA to discuss a repair (labour costs) if it less than 5 years old
    linrew
    #190393
    Re: CDA CW494
    linrew wrote:hi
    linrew
    I didn’t realish they came with a 5 year GT. Call out your local service agent then and get it done properly 😛
    #190394
    PerranOak
    Thank you both.
    Typically, it hasn’t done it for a while now but I’ll look at the flashes.
    It was in the house when we bought it but I’d gues it’s less than 5 years old, excellent!
    R.
    #190395
    linrew
    Re: CDA CW494
    hi
    if you call CDA with all the numbers (from a sticker usually on the kickplate on the bottom of the machine) they will be able to tell you how old the machine is
    sorry i dont have a number for CDA
    linrew
    #190396
    Re: CDA CW494
    the serial number **04 ****** **** is the year and
    **** 24**** **** is the week number it was made.
    #190397
    PerranOak
    Oh wow, cheers. I’ll look!
    R.
    #190398
    PerranOak
    Re: CDA CW494
    kandl-appliancerepair wrote:when you open the door, count the flashes between the pauses and that will give you a fault code, let me know how many times it flashes and ill tell you 🙂
    Cheers mate. I looked and the light just flashes continuously, no pauses. What happens is that, even though I select a wash programme, it stops early, beeps and selects the rinse prog.
    Weird!
    Oh, it’s about 10 weeks out of gurantee – damn!!!
    #190399
    Re: CDA CW494
    Weird!
    I think its Mr. Engineer time im afraid! Cant help you if its flashing constantly, unless one of the others knows, could be anything!
    sorry
    #190400
    PerranOak
    Thank you for trying though!
    R.
    #190401
    Barny13
    Re: CDA CW494
    My CDA494 stops after about 15 minutes and repeates a 4 flash error code. The beep also sounds.
    Any ideas on how to reset. Thank you.
    #190402
    Re: CDA CW494
    this is showing a pump out failure.
    bryan
    #190403
    grizz
    Re: CDA CW494
    I’ve got a cda 494 as well , i’ve got a blink code fault . It flashes 7 times .
    Can any one help .Thanks grizz
    #190404
    Re: CDA CW494
    This fault is either no water or the water flow meter faulty.
    Bryan
