Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › clearing blockages
- This topic has 15 replies, 6 voices, and was last updated 19 years ago by
fasetester.
March 23, 2007 at 4:13 pm #26091
fasetester
Participanthi guys would any of you clear a blockage in a dishwasher with one of those pumps for un blocking drains and sinks where you pump it up and then fire a blast of air to unblock the pipe what is your thoughts fasetester 🙂
March 23, 2007 at 4:22 pm #208737iadom
ModeratorRe: clearing blockages
If I wanted to blow the internal hoses off and flood the kitchen then that is one way I would go about it. :rolls: 🙂
March 23, 2007 at 4:49 pm #208738Martin
ParticipantRe: clearing blockages
March 23, 2007 at 5:44 pm #208739goosegreen
Beg to differ on this one, But I use my Pango drain cleaner all the time. Not from the open end of the hose as most machines have non return valves, But from the pump end it works a treat 😆 I mainly use it to clear pressure switch bottles, saves crawling about under the machine and it works especially well with Zanuss,is. You dont have pump it up to it full pressure and the customers are impressed when the waste stand pipe is blocked and you get your big orange gun out and saves her calling a plumber 😉
Goose
March 23, 2007 at 6:18 pm #208740fasetester
Participantso iadom and martin you say dont do it unless you want a flood and goosegreen says it works for him if you go about it the right way not even if you use a gentle puff to clear metering tank blockage or sump or pressure chamber blockages are you guys talking from experience just a thought but you always listen to the guys who have been there got wringing wet teashirt to prove it :lesson: 🙂 fasetester
March 23, 2007 at 11:15 pm #208741iadom
Your first post clearly said, ‘ clear a blockage in a dishwasher’ , not in the outlet pipe or the sink waste pipe. I carry a can of compressed air, the type you buy from computer shops to blow the dust out of your PC. I often use this to clear gunged up Zanussi washing machine pressure chambers. I would not risk using a drain cleaner pressure gun on the internals of a dishwasher.
I have seen several instances of ‘air’ pressure blowing pipes off inlet valves and soap dispensers after the mains water has been turned off and back on again.
March 24, 2007 at 12:42 am #208742fasetester
Participantpoint taken jim so keep it for the drains and sinks are the any good for unblocking drains sinks ect so to be on the safe side use something flexable or strip down fasetester 🙂
March 24, 2007 at 1:18 pm #208743fasetester
hi guys i thought their would have been more of a responce put it another way what do you all use to clear blockages in dishwashers ect fasetester 🙂
March 24, 2007 at 2:49 pm #208744Martin
Wouldn’t be without my……..
March 24, 2007 at 4:31 pm #208745fasetester
Participanttape bottle brushes what the other thing martin 😕 fasetester
March 24, 2007 at 4:35 pm #208746Penguin45
I think it’s his beloved Bosch syringe. Bottom box appears to contain a giraffe……..
March 24, 2007 at 6:13 pm #208747fasetester
Participanthow does he get the giraffe back out where do you get big syringe from 😆
March 24, 2007 at 6:36 pm #208748Penguin45
http://www.ukwhitegoods.co.uk/modules.p … ch+syringe
Syringe is in there somewhere.The giraffe? Ask Martin……….
March 25, 2007 at 9:27 am #208749Martin
Penguin45 wrote:The giraffe? Ask Martin……….
The giraffe has been captured and sent back to Longleat….. 😉
March 25, 2007 at 9:39 am #208750gegsy
Martin wrote:Wouldn’t be without my……..
Sex aids 😕 😆
