Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Creda 37373 Dryer
- This topic has 26 replies, 7 voices, and was last updated 14 years ago by
scots.
March 18, 2012 at 4:38 pm #371258
ModeratorRe: Creda 37373 Dryer
just under the text box that you enter your post into is a tab labelled ‘Upload attachment’ click on that and then browse your PC for the files you wish to upload. 😉
My sister in law has a Hotpoint model which is the same as this, I cannot see any reference to drum speeds in any manuals so I will check hers when I get a chance.
March 18, 2012 at 4:59 pm #371259scots
ParticipantRe: Creda 37373 Dryer
Hi Jim
Appreciate it.
I have never had to check this before, first time for everything.Looking at the shafts, it doesn’t look much different but I am sure the ratio must me such that the drum rotates to fast.
The dryer is mine now but its going to bug me
Oh, and as I have paid for the motor its cost meThanks
BrianMarch 18, 2012 at 5:04 pm #371260iadom
ModeratorCreda 37373 Dryer
It all seems rather odd, a simple induction motor with no electronic control should run at a set speed dependent on how many poles the motor has should it not?
I am here: http://tapatalk.com/map.php?p2eyhkMarch 18, 2012 at 5:13 pm #371261scots
Yes , thats my point Jim..
It is a simple induction motor, set poles so speed is set with the mains frequency.But trust me the speed the drum rotates at is way to fast. With clothes not tumbling. They stick to drum?
I have been in touch with Masterpart but the tech guy said that this motor is correct and to be fair, all other suppliers have this as the correct motor.
Going to try and get the exact speed of the drum rotation on Monday.
Might even video it
Brian
March 18, 2012 at 7:05 pm #371262clockworkone
looking at new shaft there is quite a difference.if rpm on both shafts are the same i would think new shaft will add up to 50{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} to drum speed.as iadom says it has to be motor as i doubt if theres anything built into mechanics of m/c to regulate motor.
March 18, 2012 at 7:17 pm #371263iadom
I haven,t said the motor is faulty, I. Have an open mind ATM. Personally I don’t think there is enough difference in the size of the shaft to make any real increase in speed so noticeable.
Sent from my iPad using Tapatalk HDMarch 18, 2012 at 8:18 pm #371264clockworkone
sorry Jim could have worded last post a little better,what i meant to imply was that ratio of new motor shaft was different to old one and not faulty manufacture.
March 19, 2012 at 8:44 am #371265Martin
scots wrote:initially noisy which turned out to be the motor.
Stick a pair of ball race bearings in the old motor and that will solve everything. 8)
March 19, 2012 at 1:34 pm #371266scots
wish I had now Martin .
Checked drum speed this morning and its at 76RPM!!!
March 19, 2012 at 2:10 pm #371267iadom
I did a job this morning on a washer and the customer had one of these so I checked it out. It was around 70 rpm.
Hoover used to calculate 85rpm as plaster speed, at Hotpoint we used to set it to 88rpm.
March 19, 2012 at 5:12 pm #371268scots
Old noisy motor refitted and drum now at 63rpm,
Have rebuilt with new motor and using it for drying.
Bloody thing works ok!! drys fine!Customers!
Will try selling it as a cheep machine as its in near perfect condition, might get money back for motor.
Lost this one but customer for life.
March 19, 2012 at 5:15 pm #371269iadom
Result. :tup:
Plus you have a spare motor that will no doubt be OK for a full size dryer. 8)
The real problem with the small 3kg dryers is people trying to stuff the full load from the washer in them. They are usually quite a reliable little machine TBH.
