Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Creda 37747 Condenser dryer
- This topic has 28 replies, 14 voices, and was last updated 20 years, 5 months ago by
walnut.
November 7, 2005 at 7:10 pm #13137
walnut
ParticipantHello,
Having problems trying to do a repair on the above dryer.
Original fault was no heat.
I found that the lower temp stat (red dot) was open circuit.
Fitted a new stat kit, dryer heating ok.
1 week later customer reports no heat again, on investigating I found the 95c
stat was open circuit again.
Are the two stats at the back of these dryers just one time only safety toc’s ?
If so where is the temp control stat?Any help gratefully recieved.
November 7, 2005 at 8:22 pm #153325bobokines
ParticipantRe: Creda 37747 Condenser dryer
The pair of stats must always be replaced as a pair. 1701583
The control stat is at the twelve oclock position above the door access and trips at 58 degrees.
The usual reason for the one shot stat failing is the customer opening the door during the drying cycle, however it usually takes more than a week for this to happen so I would investigate further.
There is a lot of information on this site about this problem. Have a probe about using the search feature. You’re not alone…
BobNovember 7, 2005 at 8:27 pm #153326iadom
ModeratorRe: Creda 37747 Condenser dryer
Are you fitting the correct stats to this machine, the red spot stat should be a 120° stat, not a 95° one. The other stat is the temp control stat. There is also another stat in the door surround.
The correct kits are as follows.Date code less than 65 (red spot 120° ) kit 1701557
Date code more than 65 (green spot 130° ) kit 1701583
you should ensure that the customer is keeping the filters and the heat exchanger clean and also not opening the door mid cycle, you must allow the 10 minute cool down period to run its course.
Evening Bob, :wave:
November 7, 2005 at 8:31 pm #153327bobokines
:wave: Hi Jim… Keep ’em coming.
November 7, 2005 at 9:25 pm #153328walnut
Thanks for the quick reply.
Still need to know if the two rear toc’s are both one shots to protect the dryer or 1 is a protector and the other temp control.November 7, 2005 at 9:30 pm #153329Penguin45
November 8, 2005 at 9:52 pm #153330streetlighter
Hi all
Lovely bit of paper in any stat kit box showing picy’s, colour of dots and date codes. With all part numbers shown.Paul
November 9, 2005 at 8:46 am #153331Martin
walnut wrote:or 1 is a protector and the other temp control.
The latter applies 😉
November 10, 2005 at 10:57 pm #153332walnut
Decided to fit a 120c manual reset toc from RS
cost 3.50.
Thanks for the advice.November 11, 2005 at 12:37 am #153333Penguin45
Got a problem with this Walnut – you may have fitted the right cut-out, you may not have. You should have checked the date code or the colour spot on the the stats and replaced them as a set. If you search the forums, you will find that these are a recurrent problem, usually caused by customer misuse; so education is usually the solution. However, it can be caused by a faulty control stat, so you may well be seeing your customer again, sooner than you think.
Gret the right kit in the van ready for next time.
November 11, 2005 at 2:54 pm #153334andy2
walnut wrote:Decided to fit a 120c manual reset toc from RS
cost 3.50.
Thanks for the advice.The only reason Hotpoint don’t do this is because they are making a fortune on these stat kits. Other manufacturers fit manual reset stats as standard so why don’t they? It does show the huge difference between manufacturers attitudes. Crosslee for instance often have their resetable easily accessable on the rear panel for the user. Zanussi use a resetable on many of their m/c but hide it under the heater access panel so most people will still call an engineer for the problem.
Having said that from our point of view they are nice little earners so not complaining!
Andy 😀
November 11, 2005 at 4:58 pm #153335Martin
cost 3.50.
Thanks for the advice.RS……what planet is that I wonder?
November 11, 2005 at 7:45 pm #153336wilf
shouldnt realy say but a squirt with a freezer spray will reset the little bu**ers (done it with my own.) IN THE INTEREST OF SAFETY ALWAYS FIT A NEW PAIR peace of mind is worth a lot
had one the other day where the blower fon was blocked with torn newspaper looked like a mouse might have got in during the summer when the dryer wasnt used only found it because of the vibrationwilf
November 11, 2005 at 8:39 pm #153337Penguin45
Martin wrote:
RS……what planet is that I wonder?Radio Spares.
November 12, 2005 at 11:16 pm #153338burns
Reversing timer sticking also gives cause to tripping plus check float chamber for sticking float, as this will often cause no heat but will not affect stats.
I am sure this has all gone down on a pre thread. ❓ -
