Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Creda 37747 Condenser Tumble Dryer
- This topic has 28 replies, 8 voices, and was last updated 21 years, 3 months ago by
Ade.
January 8, 2005 at 8:22 pm #122253
Ade
ParticipantRe: Creda 37747 Condenser Tumble Dryer
Penguin – Thanks
Clyde – You’re right!
I assume it’s the one I’ve just found next to the motor. It’s white, 3″ long and 1.5″ in diameter with a bolt thread out of the end. Markings:
7 uF +/-5{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}
400v – 30000h/cl A
450v – 10000h/cl B
500v – 1000h/cl D
-25/85/21
400v – 10000h/cl D
-25/100/21Cheers again
Ade
January 8, 2005 at 8:38 pm #122254Penguin45
ParticipantThat one’s not in Shop@ – yet! Dave’ll sort it.
Chris
January 8, 2005 at 8:56 pm #122255Ade
Chris
I have every faith after thinking I’d have to ditch the machine last time. It has been a good servant but if I can keep it going a bit longer it would help especially given post-Christmas credit card bills… 😥
Thanks anyway – now off to have a drink after crawling around the utility room floor for most of the evening. 😉
Cheers
Ade
January 9, 2005 at 1:52 pm #122256Dave_Conway
ParticipantPenguin45 wrote:That one’s not in Shop@ – yet!
It is now 😀
Link here for you Ade:
http://shop.ukwhitegoods.co.uk/Tumble+D … citor.html
January 9, 2005 at 5:38 pm #122257Ade
Excellent and good value too. The only problem was that when I was establishing the fault, I knocked open the door whilst it was going so I’ll be ordering some more thermostat bits!!
Thanks again – I’ll get ordering.
Ade
January 17, 2005 at 1:59 pm #122258Ade
Just a quick one to let you know that the new capacitor and thermostat bits arrived promptly and I had no problem fitting them. The machine works perfectly.
Thanks yet again for your money-saving assistance.
Cheers
Ade
July 16, 2006 at 1:24 am #122259KCU
I know it’s an old thread but I have a similar model of tumble dryer (Creda 37754 Condenser) serial number 53100217 and the same fault.
My wife called me at work to say the tumble dryer has stopped, there is a smell of burning so she switched it off, I checked it and with a little help the drum moved round therefore replaced the 7uf capacitor and it was all ok again or so I thought 😥
After 2 hours of it going round I noticed it’s not heating up so I take it the problem is the thermostat’s ?
Can someone direct me to the correct thermostat bits for me to buy if that is indeed what you would believe is the problem. Also what panel would be the best to get to in order to replace the thermostat bits, side/rear/top ?
Is this the correct one ?
http://shop.ukwhitegoods.co.uk/Tumble+D … t+Kit.htmlI will make sure plug is not only removed from the plug socket but actually removed from the lead to make sure no nasty shocks occur :zap:
July 16, 2006 at 7:19 am #122260Dave_Conway
KCU wrote:Is this the correct one ?
Yep, that’s the one :tup:
July 16, 2006 at 8:16 pm #122261KCU
Thx Dave, ordering them now 😀
July 18, 2006 at 12:41 am #122262KCU
KCU wrote:Also what panel would be the best to get to in order to replace the thermostat bits, side/rear/top ?
Can anyone shed some light on the whereabouts I will find the thermostat bits that I will be replacing on this Creda Condenser Tumble Dryer (37754) ?I want to be ready for when they arrive and would prefer not to take every panel off searching.
Thx in advance.
July 18, 2006 at 7:28 am #122263Martin
KCU wrote:Can anyone shed some light on the whereabouts I will find the thermostat bits that I will be replacing on this Creda Condenser Tumble Dryer (37754) ?
You’re a repairer? They are adjacent the heater which is at the back!
July 18, 2006 at 12:54 pm #122264KCU
Martin wrote:
KCU wrote:
Can anyone shed some light on the whereabouts I will find the thermostat bits that I will be replacing on this Creda Condenser Tumble Dryer (37754) ?They are adjacent the heater which is at the back!
Parts arrived this morning, swapped them over in 10 mins and now have heat again. Thx for the hint in direction as saved me time searching 🙂
RegardsJuly 15, 2017 at 2:59 pm #122265rai555
Hi all,
i am new to the forum and need some help:Thumble drier blows main fuses about 5 minutes from the start, looking inside looks like capacitor is ”cooked”
The markings are: KPB 7336 X1Y2
0,1 uF +2 x5000 pF
275v 25/085/21/BI wonder where about i can buy same or replacement?
Many thanks in advance
RaiJuly 15, 2017 at 3:35 pm #122266Martin
If you reside in the UK, Maplins, Farnell or RS.
