Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Creda Condensair Model 37754 Doesn’t heat
- This topic has 23 replies, 7 voices, and was last updated 21 years, 4 months ago by
admin.
November 16, 2005 at 9:13 am #120060
ParticipantRe: Creda Condensair Model 37754 Doesn’t heat
scott1 wrote:What does this box do and could it be a contender.
It is the ‘Reversing Timer’ and cuts supply to the heater for a few seconds whilst reversing. They often fail (Part No 1701133) available by emailing the details to spares@ukwhitegoods.co.uk
November 16, 2005 at 9:32 am #120061scott1
Dave/Martin
Thanks for the info. Before I go ahead and replace this timer unit, can you tell me what the black box next to it is. This black plastic part is not part of the timer block, and looks (very difficult to see) like the micro switch used on the door. Could it be an air flow sensor or weight sensor?
Scott
November 16, 2005 at 10:14 am #120062Dave_Conway
We only have line diagrams to work with Scott so I don’t quite know which part you mean, I think though you refer to the float chamber. There is no air flow or weight sensor in the dryer 😉
November 16, 2005 at 10:28 am #120063scott1
Hi Dave
I am not sure if this will make it any easier to establish what this part is, but it does seem to have a thin length of metal which sits in a V shape piece of plastic. When I raised this metal arm I could hear a switch contact noise.
If the fault is actually the timer rev what is the best way to prove it is at fault?
Scott
November 16, 2005 at 10:38 am #120064Dave_Conway
Yep, that’s the float chamber by the sound of it.
Continuity test as I mentioned previously to check 😉
November 16, 2005 at 11:29 am #120065scott1
Cheers.
Is there a datasheet for this reverse timer available, so I can determine whether is functionally sound?
Scott
November 16, 2005 at 11:40 am #120066Dave_Conway
I’m afraid not, even we aren’t privvy to such material without being charged through the nose for it 🙁
November 16, 2005 at 11:54 am #120067scott1
That doesn’t surprise me. I plan to carry out the continuity this evening, please advise which pins on the timer unit should be connected together or not as the case may be.
Scott
November 17, 2005 at 8:29 am #120068scott1
Thanks for the advice. As it turned out it was the thermal switch by the door which was faulty. Out of circuit is measured as closed but the mere sniff of warm air caused it to open. I could get it to open with the heat from my finger.
Scott 😆
