Creda T620CW
  • #57786
    jontymox
    Good afternoon all,
    Has anyone come across the above condenser tumble dryer not filling the condensation draw, thus being very inefficient.
    The heater works, and the customer states m/c takes a long time to dry laundry.
    I have carried out a few visual checks etc, and removed the drum to gain access to the main components.
    However, I’m unsure what can be causing the problem.
    There doesn’t appear to be any leaks or blockages, and would appreciate some advice.
    Best wishes,
    jontymox
    #332303
    Re: Creda T620CW
    ? is heater working ok
    ie half heat only or exhaust stat not working properly
    if its working ok you would expect a lot of steam to come out of dryer when door is opened mid cycle
    Re: Creda T620CW
    Pumps are a bit unreliable, if it has one.
    Mike.
    #332305
    Re: Creda T620CW
    No pump, really has to be a blockage or possibly loose fan.
    You have to remove the condensor completely making sure it is clean and then lie down on the floor and reach right back into the condensor chamber and have a good feel around. Usually lots of gunge can be pulled out from the back.
    #332306
    timdowning
    Re: Creda T620CW
    Is this the full metal door type dryer, I think it is.
    Did you take the filter out and look inside the door itself. Had loads of these with extended drying times due to this.
    #332307
    jontymox
    Re: Creda T620CW
    Good afternoon all,
    Still struggling a little with this T/D problem.
    I’ve re-assembled the unit, and re-tested as no inner door, or condenser chamber blockages as suggested.
    The heater does get warm, as stated.
    However, it doesn’t seem to be getting hot enough, as no steam evident and only moderate heat on damp towels when checked mid-cycle.
    Maybe it does require a new heater unit, as there is little/no difference between high or full heat too.
    Also wondering if the condenser unit could cause the problem, and if so, how does one test them?
    Best wishes,
    jontymox
    #332308
    Re: Creda T620CW
    You can’t ‘test’ the condenser, its just a simple, two way airflow chamber. It has to be as clean as possible looking from end to end and side to side.
    Warm, moist air is blown through one side, cool air from outside is blown through the other side to cause the condensation.
    You say you have done visual checks, how about electrically testing the element?
    If you a a suitable plug in energy meter you can test to see if it is working on both high and low heat or check at the consumer unit.
    There is also another thermostat located inside the top of the door housing that can cause no heat. I have had these cutting out under load once or twice.
    #332309
    Allsorts
    Re: Creda T620CW
    Also check that the heat option switch is fully working
    George
    #332310
    jontymox
    Re: Creda T620CW
    Good evening,
    Thanks chaps,
    The condenser unit is getting wet; is this normal, and definetely requires a good clean out…
    How does one do this?
    Best wishes,
    jontymox
    #332311
    Allsorts
    Re: Creda T620CW
    jontymox wrote:Good evening,
    Thanks chaps,
    Best wishes,
    jontymox
    It is normal that the condensor will get wet but with these condensor dryers it is a requirement for the condensor unit to be kept clean… They are supposed to be cleaned after each use but noone ever does… I would say it is imperative that they are cleaned at least once in each fortnight as a minimum if they are to operate anywhere near normally.
    best way to clean them (if you have the time) is to soak for an hour in a bath of warm water and then rinse from all directions with the tap on full.
    George
    #332312
    Re: Creda T620CW
    The best way to clean them full stop, is outdoors with a pressure washer. An outside hosepipe will suffice as long as the water pressure is decent though.
    It makes me laugh when you see the advice in the user manual, it shows a picture of someone pouring water from a jug into the condenser to clean it. :rolls:
    #332313
    Re: Creda T620CW
    i use a jug and a piece of wire coathanger with the last half inch bent at 90 degrees and the other end bent over in case i poke my eyes out
    RocketMan
    Re: Creda T620CW
    I find that if you thoroughly wet them first – allow the lint to absorb the water. 5-10 minutes (a sink is perfect if big enough) Then try and clean it out. Have you tried moving dried on lint? it’s quite difficult. It comes away a lot easier when it’s been wet and allowed to absorb water…
    #332315
    Re: Creda T620CW
    Allsorts wrote:
    jontymox wrote:
    Good evening,
    Thanks chaps,
    Best wishes,
    jontymox
    George
    😆 It would kind of make it hardly worth the bother of using a tumble dryer if you had to clean the condenser unit after each use! (I think you mean the filter). Could save a hell of a lot of energy by causing people to use their washing lines!
    Mike.
    #332316
    Allsorts
    Re: Creda T620CW
    “leavemetogetonwithit wrote: 😆 It would kind of make it hardly worth the bother of using a tumble dryer if you had to clean the condenser unit after each use! (I think you mean the filter). Could save a hell of a lot of energy by causing people to use their washing lines!
    Mike.
    :rolls: ROFL Mike .. I have one of those machines here and the sticker inside the door says “Clean filter and condensor after each use”. I do agree it would be a pain to do so, however, I think you know that when I said ‘soak the condensor in a warm bath for an hour’ I was meaning do so if the filter was all choked up with s**te.
    George
