Home › Forums › Public Support Forums › Spare Parts Help › Creda T632CW Thermostat
- This topic has 16 replies, 6 voices, and was last updated 21 years, 1 month ago by
admin.
March 2, 2005 at 10:35 pm #8242
KeymasterI need a replacement thermostat for a Creda T632CW Tumble Dryer. THe top is marked TOD J1 and the back has a green dot. How much does one cost and what is the postage?
March 3, 2005 at 1:00 am #127591Penguin45
ParticipantDavid,
Go into Shop@ and order 1701583.Regards,
Penguin45.March 21, 2005 at 10:07 am #127592admin
KeymasterRe: Creda T632CW Thermostat
David Wells wrote:I need a replacement thermostat for a Creda T632CW Tumble Dryer. THe top is marked TOD J1 and the back has a green dot. How much does one cost and what is the postage?
Does your’s have the same problem as mine? – No heat at all although drum goes round. Is it the thermostat or element?
March 21, 2005 at 10:38 am #127593Dave_Conway
ParticipantRe: Creda T632CW Thermostat
It could be either Toni, more likely is the thermostats though 😉
March 21, 2005 at 12:53 pm #127594admin
Dave_Conway wrote:It could be either Toni, more likely is the thermostats though 😉
Wow, cheers for answering so quickly, Dave! 😀
I’ve had the back off & the metal appears to be slightly in, rather than convex. I couldn’t work out how to remove them though as they seem to be attached to wires!
I’m very good at taking things apart but always forget the order in which parts are replaced. Is there a picture anywhere of how the 3 covers (at the back) go, please.The door on my ancient Indesit Prestige Line 1000 washing machine has been broken by my kids! Would a door still be available for such an old model? 😳
March 21, 2005 at 1:54 pm #127595Martin
Anonymous wrote:The door on my ancient Indesit Prestige Line 1000 washing machine has been broken by my kids! Would a door still be available for such an old model? 😳
Give us the full model number of this beast(on the back panel) and we can look it up for you :tup:
March 21, 2005 at 1:58 pm #127596admin
Martin wrote:
Anonymous wrote:
The door on my ancient Indesit Prestige Line 1000 washing machine has been broken by my kids! Would a door still be available for such an old model? 😳Give us the full model number of this beast(on the back panel) and we can look it up for you :tup:
Cheers but I’ll have to wait for my son to come home to pull the machine out!
March 23, 2005 at 3:50 pm #127597admin
Martin wrote:
The number is
WN 1061 WR
(looked through a mirror in the end, so I hope I’ve read it right!)March 23, 2005 at 3:55 pm #127598Martin
The good news is all the door parts are available (all sold individually) so what part of the door is broken and is the door hinge OK?
March 23, 2005 at 4:30 pm #127599admin
Martin wrote:The good news is all the door parts are available (all sold individually) so what part of the door is broken and is the door hinge OK?
I think it’s the hinge pivots that are broken. The actual hinge is OK but the metal rod has broken both of the pivots.
How much would a complete door cost?March 23, 2005 at 5:13 pm #127600Dave_Conway
Anonymous wrote:How much would a complete door cost?
You can’t buy the complete door I’m afraid, it’s all individual parts as Martin mentioned.
Probably the hinge and the two plastic hinge blocks inside the door, best to check exactly though please.
March 23, 2005 at 5:25 pm #127601admin
Dave_Conway wrote:
Anonymous wrote:
How much would a complete door cost?You can’t buy the complete door I’m afraid, it’s all individual parts as Martin mentioned.
It’s just the hinge blocks – if they are the same as pivots. The actual hinge is OK. I just thought it might be easier just to change the door as the hinge posts are quite fiddly.
Many thanks for your help.March 23, 2005 at 10:50 pm #127602Dave_Conway
Anonymous wrote:It’s just the hinge blocks – if they are the same as pivots.
These things then:
They come as a pair and are £7.50 inc VAT and postage.
If you’d like some ordered for you, drop me an email to spares@ukwhitegoods.co.uk
December 13, 2005 at 9:47 pm #127603JohnBarwise
I noticed that a Creda T632CW Tumble Dryer was mentioned above where the drum will still rotate, but the dryer isn’t getting hot. This is what has just happened to mine.
It also says that this is more likely to be the thermostat than the element (I have managed to get the small back panel off, and it seems the element is in tact at least – though whether it’s still working I wouldn’t know). Is it possible for me to order a spare thermostat from somewhere, and would it be possible for me (a relatively proficient DIYer) to replace?
Also, is there anywhere that will have some sort of diagram or instructions that shows how this dryer is put together, as there is obviously nothing in the instruction manual that shows you how the dryer works? I actually don’t even know where the thermostat is at the moment.
Really don’t want to shell out for an engineer if it is a simple problem that I could fix myself (though obviously if it isn’t this I’ll have to). Any help anyone can offer would therefore be very much appreciated!
John.
December 13, 2005 at 11:01 pm #127604Dave_Conway
These should help:
http://www.ukwhitegoods.co.uk/modules.p … pic&t=2293
http://www.ukwhitegoods.co.uk/modules.p … pic&t=8729
http://www.ukwhitegoods.co.uk/modules.p … pic&t=9246
You can get 1701583 here 😀
Power off please when checking :zap:
